Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Lights Don't Come on and Start Cycle
This is a 3 year old machine.  The problem is a consistent one.  The wash selector lights do not come on and therefore, the cycle does not start.  The other lights come on when you press those buttons.  I turned off the electric from the box for 30 minutes and then on with no luck.  I can play with the buttons and after 15 minutes get the dishwasher to work a full cycle (not test cycle).  What are the possible problems and solutions?
  • 5 more comments
  • rgletter
    rgletter Dec 07, 2007
    I should add that I took off the front panel last night.  I checked for loose wiring - none found.  I checked for any replacable fuses - none that look familiar.  Does that leave the replacement of the system board, a sensor problem, or something else?  The Kenmore dishwasher gets used about twice a week.  When it works, it does a fine job of cleaning dishes.
  • rgletter
    rgletter Dec 10, 2007
    Today I was able to get the NORMAL cycle to run. In the middle or at the end of the drying, all the lights went out. There is about a 1/2 inch of water at the bottom of the dishwasher. Now, no lights will go back on. I tried to reset it by turning off the power for 30 minutes and then back on with no luck. It could be a fuse, thermastat, system board, or some sensor. Let's hear from the experts. What could be wrong???????
  • rgletter
    rgletter Dec 11, 2007
    I took off all the panels last night. There is power going to the machine and the wiring is fine. On the top right side of the upper panel is two wires - maybe fuses as suggested in other comments on this site. One wire is black and white (left) the other is all black (right). With a meter, there might be a problem with the black and white one - no reading with power on. The all black wire had a reading. I'm not sure where these wires lead to or if this is the problem. The big question is why were the cycle lights working and the options not at one point before everything turned off. I hope someone can help me out here so I can fix this ASAP. Thanks.
  • rgletter
    Uploaded picture of inside control panel.
  • rgletter
    rgletter Dec 22, 2007
    Thanks!  I checked the wiring but will take a closer look.  I doubt that is the problem since it only has been 3 years - then again anything is possible.  But, a broken wire does not explain the problems I had - its more the logic board.  The fuse is bad.
  • rgletter
    I replaced the control board, door switch (even though it was good), and the thermal fuse.  Lights come on but back to the original problem: the Cycle lights will not come on.  The three Option button/light works.  This leads me to the expensive keypad control.
    As for the suggestion of the wires, I traced them all down to the bottom and they look fine.  I also took notice to how they are assembled in this model (3 yrs old) - they reside in a molded plastic casing that minimizes wire stress when the door opens/closes.
  • rgletter
    rgletter Dec 29, 2007
    Its Fixed!  It cost about $160 to fix it myself and learn something new.  This maybe your solution for your Kenmore Dishwasher.  It turns out that the touchpad was bad and eventually took the fuse that sits on the control board.  The original control board is fine. I peeled away the front of the touchpad (after I confirmed it was bad with a new one).  The thin wires from the ribbon cable are bad right where it bends to go behind the touchpad.  This could be a defect or as one person pointed out a problem with the design of the dish washer during the drying cycle.  After my investigation, I found the most troubled areas for my Kenmore are the Touchpad, Control Board, door switch, and the fuse.  If you have problems with the bottons on your Kenmore most likely it is related to the touchpad and/or the control board.  If the lights don't come on then the fuse is blown and needs to be replaced However, something made the fuse blow (wiring, touchpad, control board, surge in electrical system, etc.).  Also, don't give up, as some here suggested.
You need to take voltage checks at the control make sure you have voltage coming to it before you replace it. It sounds like you've got plenty of money into it already It might have been cheaper to call someone.
Posted on Dec 22, 2007
    Problem Solver:
  • 14 Answers
Sounds like you need a control board (timer) or possibly a console/touch panel. One easy way to tell if it's the touch panel - turn lights off in the room and look for a faint glow from any of the indicator lights (when the dishwasher is NOT in use). This is a quick way to tell, but is not ALWAYS the case with a bad console. The 2 wires on the upper right you refered to DO go to a THERMAL fuse that is attached to the grey control board casing. When those fuses blow it does tend to be toward the end of the cycle and will almost always leave water in the bottom. If that fuse is blown the dishwasher will do NOTHING but that doesn't explain your earlier problems. If the fuse is blown you will need to replace it before doing the console check mentioned earlier and make sure you get the fuse KIT that comes with a new harness and not just the fuse itself. And, as always turn the power off before making any repairs and DON'T do anything you are uncomfortable or unfamiliar with.
    Scholar:
  • 146 Answers
Okay, I know you said you checked for loose wires but did you check for broken wires. What you will need to do is trace each wire from under the dishwasher to where it comes into the control panel. The reason I say this is because the wiring comes up from under the dishwasher into the door and up to the panel. What happens is the wires break internally from the door being open and closed this puts a stress on the wiring. You won't be able to see the break because it tends to break inside the coating and you can't see it. Which is why you need to trace the wires. If you find one broken make sure you don't splice it at the bottom. Run a completely new wire from underneath all the way to the control. I have seen this problem more than I can remember. Good luck.
Posted on Dec 21, 2007
  • Kelly Sullivan Dec 30, 2007
    Good Job. You may want to clean your float and spray arms just as a preventative service. That will help with all these problems in the future. Again Good job!
    God Bless
Maytag centennial washer why does it only run on the spin cycle?
Does your machine have a lock/start button?
It may very well be that the selector dial has some internal looseness or corrosion. Has the top control panel been wet?
May 26, 2014 | Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Hotpoint WMF940 Washing machine - 11 months old. The cycle times displayed do not represent the actual times. No 5 cycle takes over 3 hours. The other displayed cycle times are similarly not...
If it is indeed less than a year old, then I recommomend you contact Hotpoint direct as the washer will still be under the years guarantee,and you should get a call free of charge
Check with Hotpoint at the web address below.
They should be able to help you.
WWW.HOTPOINTSERVICE.CO.UK
Jan 03, 2011 | Washing Machines
Washing machine will not start
I don't think this is a GE model #, but any who, if you hear a humming <water valve sol> the product valve is not getting water to it, first, don' laugh, make sure both plumming valves are on..
If they are off and no one knows how they got turned off, it falls under the old "****-happens" deal !
May 20, 2009 | Washing Machines
Miele Dishwasher G2170 3 year old
On the display panel of the washing machine there are a few screws on the side. Remove that panel and check for power at the computer and sensor. Also make sure that when it is one and calling for water that it is getting everything everywhere
Feb 14, 2009 | Miele Advanta G2170SCSF Dishwasher
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Water keeps coming in
hi
if the water is coming in when the machine is off then you have a faulty water valve and you need to start thereand solve that problem first
cheers grantsreps
Sep 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Ariston frontloader - dial spinning around and won't start a cycle
Your bearings are almost certainly gone which would explain the noise not an easy job or cheap . Normally it would consist of a tub change or at best a bearing hub . As for the clicking round of the selector Iwould suggest poss the heater or brush fault. As ofr price you'd have to ask your local repair man. Worst case sinario approx £200 .00
May 30, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
213 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
