Question about Symphonic WV806 DVD Player/VCR
Widescreen to full screen
New movies only come in widescreen format can I switch my dvd to play in full screen mode
  • 62 Answers
You can but it'll just come out in a larger widescreen picture. if the DVD is widescreen then that's how the film was formatted. and theres no changing it.
Posted on Dec 07, 2007
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Why my regular dvd player with widescreen movies does not fill my hd tv ?
ok, There are 2 aspect ratio's for tv/movies. Widescreen Standard
If you have a Widescreen TV, Widescreen formatted dvd's will fill the hole screen, Standard formatted dvd's will not fill the whole screen
if you have a Standard TV, Standard formatted dvd's will fill the whole screen, Widescreen formatted dvd's will not fill the whole screen
this is normal, check to see the format of the dvd you are trying to use.
Jul 03, 2010 | Zenith XBV442 DVD Player/VCR
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
Dec 01, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Transfer from Widescreen camcorder through S video results in Full Screen instead of Widescreen
have you set the dvd to widescreen? i know some change automatically when there is widescreen input but some need to be changed manually. This should be in system settings. hope this helps
May 19, 2009 | Panasonic DMR-ES10 DVD Recorder
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
How do I set the DVD picture to Full Screen as opposed to Wide Screen?
That is the way the DVD makers intended it to be. The TV cannot be adjusted to change that if it is a widescreen or "letterbox" movie.
Dec 12, 2007 | RCA TruFlat 27F520T 27" TV
Helios h4000 will not play some dvd's in widescreen and are formatted 16.9
I have the same problem. Go to the set up menu and go to display and select another display setting then set it back then exit menu. It should work then
Oct 29, 2007 | Neodigits Helios H4000 DVD Player
Widescreen
just go to the setup menu and look for display options and just look for option wich says ASpect. And just set it to the full..
Sep 07, 2007 | Durabrand DUR-1700 Portable DVD Player
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
Symphonic WV806 DVD Player/VCR Logo
183 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
