TOSHIBA TP55D80 REAR PROJECTION TV.
TURN TV ON,THERE ARE LINES ON THE SCREEN IN A CONCAVE TYPE ARRAY,COLOR LINES AREN'T IN LINE WITH EACH OTHER.HAVE BEEN TOLD BY THE PERSON I GOT IT FROM THAT THERE IS SOMETHING CALLED A CONVERGENCE MODULE THAT NEEDS TO BE REPLACED.IS THIS SOMETHING THAT CAN BE REPAIRED OR ARE THEY READILY AVAILABLE FOR REPLACEMENT?IT'S AN OLDER TV,SO I DON'T WANT TO SPEND ALOT OF MONEY ON IT.THANKS ROBIN.YOU CAN EMAIL ME AT ATMAN246@YAHOO.CA
  • Robin Macfarlane Dec 07, 2007
    THANKS FOR THE INFO.IS THERE SOMEWHERE I CAN GET/BUY A SERVICE MANUAL FOR THE SAME TV?I'M NOT A TV TECH,BUT I DO WORK WITH ELECTRIC FORKLIFTS SO I HAVE SOME KNOWLEDGE AND ABILITY TO REMOVE THE BOARD AND HAVE IT REPAIRED
  • Robin Macfarlane Dec 08, 2007
    THANKS AGAIN FOR THE HELP.I WOULD LIKE TO GET THOSE PART NUMBERS IF YOU COULD.I'VE PULLED ALL THE COVERS OFF OF THE TV AND AM GUESSING THAT THE CONVERGENCE BOARD IS THE ONE MOUNTED RIGHT ON THE FRONT OF THE SET WITH ALL THE ADJUSTMENT POTS FOR HORIZONTAL AND VERTICAL,PART #PB4613-1.IF THIS IS WRONG,COULD YOU POINT ME IN THE RIGHT DIRECTION.ANOTHER QUESTION,WHAT WOULD CAUSE THE I.C'S TO FAIL?IS THIS JUST AN INFERIOR PART THAT WAS USED OR IS THERE AND UNDERLYING PROBLEM?
    Novelist:
    Champion:
  • 232 Answers
Robin, your convergence IC`s have failed, they are readily available but not an easy job for a non-tech, the board has to be removed from the tv and then the IC`s have to be un-soldered and new ones installed, this is not a real expensive repair but everyones description of "expensive" is different.At my shop this would cost approx. $265.00 out the door, Hope this gives you the info you need to make the decision, still have questions? ask away, BMW Rider
Posted on Dec 07, 2007
  • Larry Eastman
    Larry Eastman Dec 08, 2007
    Robin, just looked it up and the manual is no longer available, sometimes if you google to model number you can find them for sale in "pdf" format, be advised the regular manual was over $50.
    If you know how to un-solder & solder you can install these but it`s not easy, I`ll give you the part numbers and you can try if you want, let me know, BMW Rider
  • Larry Eastman
    Robin, front board is convergence control board, DON`t fool with that one, go to the back of your set and look for IC`s "STK392-020" there should be 2 of them screwed or clipped onto a large aluminum stand-up heatsink, the number is stamped right on the face of the large, black plastic rectangle shaped IC, approx. 18 pins, will have a white paste applied to the back of them for heat transfer. Be sure to look at the resistors that are close to the heatsink for any dis-colored or burned in the middle spots. your board should be marked Q702 right by the IC, buy your IC`s and any resistors you find bad (if any) here 1-800-575-9833 (acme in Orlando) no cheap look-alike chinese knock-offs that WILL fail in 2 months, Questions? email me, BMW Rider
Colored lines down the tv
old tv. don't put anymore money in it. get you a nice flat screen. not work it being a projection. jmo
Oct 08, 2014 | Toshiba 42H81 42" Rear Projection...
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Concaved shadow
this is because of the magnetic interference, you better isolate the TV from the devices producing heavy magnetic interferences like Speakers Microwave, Cellphones and Cordless phones. Then go the main menu in that you will find setup option , in the setup option go to the picture setup you will find option called degauss just click on that, the screen will flash for a second and everything will be alright. Frequent degaussing is not advisable as it reduce the life of the projection tube.
Jul 25, 2009 | Toshiba 50H82 50" Rear Projection...
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba TP55D80 rear projection has sunburn
nope...get a new one, my call..unless you like to do this a lot..
Mar 11, 2008 | Televison & Video
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Digital Array?
I have the very same problem. Was there a solution to landfill2004?
Nov 13, 2006 | Hitachi 50GX30B 50". Rear Projection...
Televison & Video Logo
604 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
