Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Input 7 not working
New cable box with HDMI and the TV is not recognizing the signal therefore it is not allowing me to go to input 7
  • eagle1pt Dec 07, 2007
    Sounds great, but what do I do? Take off the back of the tv to check and if so what am I looking for?
Did you go to "Label Inputs" in the settings? Make sure Input 7 is not set to "skip."
Posted on Jan 30, 2008
  • 231 Answers
Its possible cable inside tv from HDMI section to main board is loose or not seated properly ..The other thing I have seen is the actual HDMI box bad ..This is called (UD BLOCK) part #
A-1604-652-A from
Posted on Dec 07, 2007
  • crispin melchor Dec 07, 2007
    as soon as you remove the back just follow where the HDMI input is and follow any cable comming from it .If cables seem connected then procede to replace .The left side where all the inputs are .There will be a single vertical bracket on left 2 screws holding back the main chassis Once bracket is removed you should pull the chassis out fairly easy .Use good lighting and while your there its a good time to vacuum fans ..Please make sure to disassemble unit UNPLUGGED..IM sure you knew that..
T V turns on, can't get the HDMI to appear on the screen for the signal.
HDMI is the High Definition Media Interface PORT on the back of a modern Flat Panel TV or Monitor.
The remote control should allow a selection menu to appear on the screen so you can choose an alternate signal input from another device or set top box.
Perhaps the TV senses that there is no signal on that HDMI cable plugged into the back port, so therefore it won't show it on the screen menu.
Turn on the device attached to the other end of the HDMI cable.
Mar 02, 2015 | Televison & Video
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
Why doesn't my Emerson lf501em4f not recognize cable box HDMI?
Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
Sep 28, 2014 | Emerson Televison & Video
Why is tv saying no signal?
Connect a known working DVD player by using a new HDMI cable to HDMI INPUT 1 and check for signal.
If you have a DISH or CABLE system box, connect that also with a new HDMI cable to HDMI input 2 or 3 and recheck for signal. Your T V remote will have an input selector to change between the different inputs on your
T V.
Sep 08, 2014 | Proview HX303 30 in. HD-Ready LCD...
Only One HDMI Input Works
with hdmi plugged in take power cable out of apple tv ,put power plug back in then look to see if you have a signal....
Feb 05, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more:
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
266 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
