Question about Toshiba 27A50 TV
Picture and sound does not always come "on"
Red light flashes on front of TV. When tapping on the main pc board componets near the center on the board area the pic and sound comes back. Sometimes the TV will work for hours without a problem. I believe the intermittent issue is a cold joint. If someone can find the cold joint on the board that would be great!
Regards,
Trimmer
  • Anonymous Nov 22, 2008
    Hi ,
    I have the same problem. Have you been able to fix this ? How did you do it?
    I have the same issue. Were you able to fix it ? How did you do it ?
    Novelist:
    Champion:
  • 232 Answers
Trimmer, you`ve narrowed it down to a certain section and your absolutely correct that it is a bad solder joint, there are 2 things you can do, first get a bright light and a magnifying glass and go over the bottom of the board and look for it, should be fairly obvious with the magnifier, if not go here and order a can of "Freeze mist" www.partstore.com this is a great "tool" for finding intermittents, it`s coolant in a spray can, have someone watch the screen while you spray in the area of the intermittent, when you hit the bad part the set will work, re-solder the part and any joints around it that look bad, end of problem, good luck with it, BMW Rider
Posted on Dec 10, 2007
Have a samsung tv UN40H6203. sound no picture. after a reboot now no picture and no sound. red light on front works.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 06, 2017 | Samsung Refrigerators
I have a sharp tv model LC-46D82U has no picture on the back have 2 red light on, one flashing other standing, please tell me what is the problem?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Feb 16, 2016 | Sharp Televison & Video
TV red light on stand by press remote on blue light shows no picture or sound
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 22, 2015 | Televison & Video
I have sound but not picture
Tap on the screen with your finger end not to hard when the T.V. is on. If you see a white light flash, it means that the neon work, the backlight. So you should check your main board or your t-con board or a trouble in the power supply. Ask a technicien near you to check it. I would but i live to far. Best of Luck. Serge Lavallee.
Oct 13, 2014 | LG 32LG30 32 in. LCD HDTV
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Apr 15, 2009 | Toshiba 36A50 36" TV
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Picture is geen and does not stay
Lots of trouble with bad picture tubes on that model! Remove the front grill and very gently tap on the neck of the center picture tube near the socket with the back of your screw driver. If the picture flashes back to normal that means the the tube has an internal short. You may hear a snapping noise while tapping and the set may shut off. If the tube is not sensetive to tapping it it possible you have some other type of failure.
Nov 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Toshiba 27A50 TV Logo
117 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
