Question about Sony PlayStation Portable (PSP) Console
Psp fault nothing happens when i insert a disc. i can see a sensor on the left near the front and when i touch it the lazer lights up but cannot work out how a disc touches this to tell the psp to spin and read the disc. HELP. thanks matthew
  • matty5616 Dec 10, 2007
    thanks for your advise. Is there a switch or a button that is pressed when the door is closed to start the disc spinning. I think it is on the left hand side near the front and i think it is broken or missing. If i put pressure on it with a small screwdriver the lazer lights up and moves so i think the lazer is ok. Started to take the console to bits but got scared so put it back together so may have to send away. any ideas? thanks.......matthew.
  • Anonymous Feb 26, 2009
    i insert the umd disk but it says disk not able to read and this also happens with my othe games to
Can anyone help when i switch my PSP on i just get the green neon for a few minutes, the screen remains blank
Posted on Oct 01, 2008
Hi From..
 Muhammed My PSP drop in side some sup of water and the screen can't display and the memory card flash light is on when i insert the battery please is their any possible means to repair it,
Am living in Nigeria Kaduna state, if any possile means please email me amj4love@yahoo.com or 2348069515108
 Thanks.
Posted on May 22, 2008
Psp doorswitch not working
Posted on Dec 22, 2007
  • 67 Answers
Umm the thing your refering to is called the laser and it is a glass object that is connected to a screw type base.And usually if you touch this the laser just dies , you can clean it GENTLY RUB IN ONE DIRECTION by using Pure Alcohol/Methanol on a PURE COTTON BUD .OR it could be the laser dying usually very common and it needs replacement , sony can service it or you can buy the part on ebay (PSP replacement laser) and you can open it up and replace it .These guides are on google by searching psp laser replacement guide or a similar term.
Posted on Dec 10, 2007
Evey time i but in a umd it comes on and then says disk can not be read
It could be many things is the can be a bad lazer, disc rotating motor is stuck, or bad motherboard in a worst case scenario. You can check if your lazer and your disc rotating motor is working if you open your umd slot with the psp on and with a small toothpick there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive If you press this down, you should see the disc motor spin and the laser light up red. If they are in working order then it could be something wrong with some of the other hardware in the psp itself. (Caution: Do not stare directly at lazer) If one of the motor (Lazer or Disk rotating motor) are twitching or trying to move there could be some dust in the gear preventing it from turning you can try getting a needle and try to move the gear manually. If this does not work your most likely going to need to send it in for repair. Hope this helps please rate thanks!
Feb 26, 2011 | Sony PlayStation Portable (PSP) Console
ASUS DRW 1608 P3S will not load CD Rom computer program disks (it makes clicking sounds then green light goes off and nothing happens). It will play movies but there is no audio, however it will play CD's...
the lazer is not reading try cleaning it with a lazer disc cleaner. but remember most pc burners need replacing after just 2 yrs of work as there lazers burn out fast
hope this helps
Dec 28, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
I have a proton pds-2302, serial # pd230250022248. Purchased in 2006. Had been working until this year (2010). When I inserted a disc, nothing happened. I heard some whirling sounds and had difficulty...
as with all dvd type machines the lazer builds up dust and debree on the lazer lens this makes it harder for the lazer to read the incripted information on the disc. much like a torch bean being covered with a cloth the fix is simple you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem.
best of luck
merry christmas
and please remeber to rank this advice as to how well it help you.
Dec 02, 2010 | Televison & Video
My psp got wet and won't turn on what should i do ? The 1st time the green light turned on but nothing happened
If ur psp console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
Then the problem consoles....... this is mainly because of some error in board .....as a result it leads to the damage of ur psp....................try to update your system ..........
if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Oct 11, 2010 | Sony PlayStation Portable (PSP) Console
I have a 2003 isuzu rodeo. Sometimes it is hard to put into reverse. I can usually get it to work in 1 or 2 tries. the abs light came on a couple of times. what could make this happen?
I do not think shifting gears ,putting your car in reverse has nothing to do whit whit the abs to come on and off ,my isuzu rodeo did the same thing and it was a dirty sensor ABS on front wheels , There is a ring on the inside of the front disc's that works together with the ABS sensor to send information to the car computer when braking ,and must have a distance of about 1/8 of an inch between ring and sensor ,,they must not touch ,what happens is that over time dirt starts to build between sensor and ring ,and ring and sensor begin to touch ,and if they do touch ABS light will start be on and off while driving ,,most of the time the problem is the sensor and not necessarly a bad sensor ,,only a durty sensor and dirty ring ,a broken or loose wire also will activate the ABS light ,,,and about car hard to put into reverse ,you'll probably need a new clutch ,,good luck
Sep 18, 2010 | 2003 Isuzu Rodeo
Memory not readable by PSP or Computer. HelP!
Dear Friend,
you have to check the Following
  • Make Sure Your MMC is NOT PASSWORD PROTECTED
  • Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
  • Properly Inserted MMC to READER
  • Change USB port if Still Not Detecting
  • Try another MMC to Reader
  • Reinsert your MMC
  • Reboot your PC
Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
YOu are done...Solved.....
IS this HelpED you ... Do RaTe mE...
you can Feel Free contact me... Thanks for Using FixYa
Apr 04, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
My ps2 wont read discs
check the lazer if he touched it get a microfiber cloth and lightly touch the lazer and turn the ps2 back on it should work
Oct 22, 2009 | Sony PlayStation 2 (PS2) Console
PSP dropped
you have messed up the UMD drive or lazer
probertly knocked the lazer off the tracks
hope to of been of help
Mike @ psp-repairs08
Mar 27, 2008 | Sony PlayStation Portable (PSP) Console
Psp trouble
I think the back of the lazer assembley might have come loose or off. It happened on my old psp. Every time it would load, a flickering red dot would appear. I dont think you can gat the back of the lazer assembley, but the lazer assembley itself can be bought for a reletively low price on eBay. Pretty easy to replace too. 4 screws and 2 cables.
Feb 20, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
390 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
