JVC Hello. I have a 27" JVC t.v.- when I attempt to turn it on, it will come on for a few seconds and then the red blinking timer light begins to flash. It was working perfectly fine one minute and then this problem started to occur, anything that can be done, or is this t.v. a goner?
  • 934 Answers
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Posted on Dec 07, 2007
Www.tameerkar.com can help you but this site is a persian site !
Posted on Nov 08, 2008
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Tv won't turn on
You can try checkin the fuses I had a problem like that with my stereo receiver took it apart changed the fuses works great
May 06, 2009 | JVC AV-27530 27" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
Television want turn on
Bill
Nov 15, 2007 | JVC AV-27230 27" TV
T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Aug 09, 2007 | JVC AV-27F702 27" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
