Question about Philips Magnavox 51MP392H Rear Projection Television
Sound My girlfriend sat on the universal remote control , now we have no sound I have a magnavox 51" rear projection Model No. 51MP6100D Serial No. YAIAO527012931 Hope someone can help me with this problem Bill
  • Becki28 Dec 14, 2007
    I sat on my remote and now the audio is very low at the speakers. The volume is at 100. I have tried unplugging the t.v. and plugging it back in, and still no audio. The t.v. had no problems before this, and is only 2 yrs. old. All I can think, is that it did something to the memory. Do you have any other suggestions?
  • 934 Answers
Bill,
That's a DPTV585 chassis I believe and there are no known common problems with the audio circuit. Does the volume bar still come on-screen when you change the audio level? When you turn it up high is there any faint sound or static noise you can hear? Any possibility it's just muted?
Try unplugging the unit for 15 minutes and plug it back in and see if the audio returns. That will reset the micro in case that's simply latched up and confused over what command(s) it was given. And let me know.
Bill
Posted on Dec 13, 2007
  • William Rayburn
    William Rayburn Dec 15, 2007
    At this point no other suggestions you could try from a customer standpoint - except to check the audio menu and make sure your settings are at internal speakers, no muting, and not SAP. (second audio program) mode.
    Beyond that a tech will need to trace and signal test the audio circuit to find the audio sample and then determine why the sample is not being amplified. Usually it turns out to be the audio output Ic or audion decoder and neither is all that expensive.
    Good Luck!
    Bill
Need a Magnavox remote control
By an universal control that states on rear packaging model and brand name that your where using .
Jul 24, 2014 | Philips Magnavox 20MS233S 20" TV
Do not have remote for ptv916 and universal does not work. Went thru every code 4 times....
As with almost all phillips products universal remotes just do not get the job done; If the model number is 9P6034C try this link:
http://www.everytvremote.com/remote-control/philips-magnavox/tv/9p6034c.aspx
If it is a different model number: GOOGLE THE MODEL NUMBER WITH THE WORD REMOTE AFTER IT, LOTS OF THEM AVAILABLE.
If you have questions or need help comment here.
SD TECH
May 11, 2011 | Philips Magnavox 9P6034C 60" Rear...
Ihave a 52" Magnavox rear projection TV. Model no.
You need a convergence kit available at tvrepairkits.com
Jan 04, 2011 | Philips Televison & Video
My television is actually a magnavox 51mp6100d/37 51" rear projection and im having a problem with the picture! it is really bright in the middle and then going towards the outsides it gets darker and i...
YOU HAVE ALGAE IN THE BLUE AND GREEN TUBES IT DOES NOT GROW IN THE RED TUBE TAKE OFF THE FRONT COVER AND LOOK IN THE TUBES COMPAIRE IT WITH THE RED WHEN IT IS ON WITH A PICTURE WILL NOT HEART YOU TO LOOK IN THEM WITH IT ON DONT TRY TO FIX IT YOUR SELF
Feb 09, 2010 | Philips Magnavox 51MP392H Rear Projection...
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Aug 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 51" TV Screen
take the broken piece to the hardware store and have a piece of plexiglass cut the same size. thats what we did and it worked really well.
Jan 31, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
