Question about MTX Thunder 1501D Car Audio Amplifier
Amp problem I have a 1501d and something is wrong with it. it feeds back trough the whole system. and when i turn on the radio the bass goes crazy but the volume from the stereo is down all the way. i called mtx and they told me thay cant repair those amps anymore. How can i fix this amp does anyone fix these anymore? please help
  • 3 more comments
  • erobles Dec 07, 2007
    thanks pbabin i opened the cover and i found 2 transistors burned and the the rca shield seems fine. could those transistors cause that problem?
  • erobles Dec 10, 2007
    thanks again my fault the number that it has are fa34 followed by the ohms sign and es2d just bellow that number. could this cause my problem if so where can i fix it?
    where can i get it fixed?
    WHERE CAN I GET THE DIODES FROM HERE IN DENVER LOCALLY AND CAN I DO THIS REPAIR MYSELF? O HOW CAN I CHECK THE REST OF THE AMP OUT TO SEE IF THAT THE ONLY THING WRONG WITH IT. THANKS AGAIN
  • oliva77kio Feb 02, 2009
    i have a mtx te 1501d amplifier 3 transistors burned off. what kind of transistors do i need and where can i purchase them. i am new to this.....
  • 631 Answers
These amps have a problem with broken shield connections on the RCA jacks. If the shield breaks loose from the frame of the RCA jack, you will have this problem. If you disconnect the amp from power and pull the cover, you can check to see if the shield is loose in the frame. if it is, it needs to be soldered.
You can also have this problem if the shield ground opens on the head unit.
Posted on Dec 07, 2007
  • 2 more comments
  • Perry Babin Dec 07, 2007
    Which transistors (Rxxx?)?
  • Perry Babin Dec 10, 2007
    If those diodes are shorted, it could cause noise problems.
    The part number is ES2D. They are diodes.
    Available at Mouser.
    Generally, one of the two diodes is burned when the chassis ground is lost or intermittent. The other one will fail when a power source comes into contact with the RCA cable shields. This generally damages the head unit also. It's VERY rare for both to burn.
    It's possible that changing them will solve the problem but there's a good chance that there are other problems.
    If you decide to work on this amplifier, do not remove it from the heatsink. There is a tiny LED in the center of the large capacitors. If it is lit, do not touch anything inside of the amp. It will remain lit until the main filter capacitors are discharged.
    Of course, you need to remove the power source from the amp whenever you're working inside the amp.
    If the only problem is the burned diodes, most any reputable shop should be able to repair it.
    If you get the amp repaired, be very careful reinstalling it. The output transistors are essentially unavailable. If you make a mistake when reinstalling it, the amplifier won't be repairable.
    I don't know if the diodes are available locally. If you order from Mouser, you'll probably receive them within a few days.
    I don't know if you can replace them. It should be a simple repair but if the traces are damaged it could take a bit more time. You'll need a good soldering iron to remove and replace the diodes.
Airplane sound comes from car audio system speakers only when I turn the radio on.
this sounds like you may have a bad alternator or radio was install wrong.the alternator has a built in condensor to stop the back feed into radio,
I would make sure the radio is installed correctly first, all it takes is a wrong wire in the wrong spot to cause this type of problem, another thing that causes this is if you have an amp connected, the amp must be wired correctly, make sure there is a good ground a soild ground close to amp and power is coming from battery to feed amp and not from fuse box.
Dec 23, 2012 | Cars & Trucks
I have a 2001 Chrysler T & C Limited. My tilt broke and tried to repair it. Finally located a whole new steering column (couldn't just replace a part.) When it was all back together everything...
If the clock goes out with the hiccup the radio system is losing total power. Have you had the radio tested??If you have & without being there to help I would check the wires in the column first. Could be a short in the steering wheel radio control or ingition switch. I figure you have them with power everything. I always check to see if proper voltage is being suppied to the connector. Check the counnector on the window & hatch motor first. If you want to post back I give you a hand solving the glitches. I have a 03 GC ES LOADED.
Feb 03, 2010 | 2001 Chrysler Town & Country
Gain makes subs go crazy when turned up
HI DUDE UR AMP IS TO POWERFULL FOR THE SUB ... .... LOWER DOWN BASS IN UR PLAYER ... AND AMP .... TRY ADJUST BACK THE TUNE ... IT WILL B FINE ....
Apr 14, 2009 | Kicker KX800.2 Car Audio Amplifier
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
Most power out of amp w/out blowing subs
you may only be able to get but so much out of the subs. If you turn the bass down a little so the that you dont drive the subs so hard you may get a little more wattage out of them
Apr 06, 2009 | MTX Thunder 1501D Car Audio Amplifier
Mtx thunder 1501d
yes you can not run amps with your speakers being grounded un ground and then try
Nov 26, 2008 | MTX Thunder 1501D Car Audio Amplifier
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Aug 19, 2008 | MTX Thunder 1501D Car Audio Amplifier
Mtx 1501d
ARE U USING THE CONTROLS THAT CAME WITH THE AMP?
USUALLY THE CONTROLS CABLE GOES BAD
May 08, 2008 | MTX Thunder 1501D Car Audio Amplifier
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Apr 15, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
MTX Thunder 1501D Car Audio Amplifier Logo
185 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
