Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Blue color Have no blue color in picture. went into convegence service mode 1-8-3 and the blue gun does not show up. Called a TV repair shop was told the crt was known on as he called it "cheap models" to grow algae and wanted $275 + tax to repair if brought in to his shop. Is there any way to fix this cheaper, or do I need to buy a new 1080p tv?
  • Bill Fenton Dec 06, 2007
    Forgot to state that the blue does show up on convergence menu 1-8-3 but is very fuzzy and the grid cannot be seen.
    Genius:
  • 1,030 Answers
As far as alge ...i cant comment on that. it just sound like your blue tube has quit altogther/...yes they can be quite expesive..however it could be crt board..maybe...buy you a new one...LOL
Posted on Dec 07, 2007
TV rca hd 52w59 has convex picture. can I fix it.
If convergence adjustment did not correct the problem likely the convergence IC's have failed and will need to be replaced along with a few defective resistors in that circuit. If you have never attempted TV repair this would not be a good repair to start on.
The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test EQUIPMENT to determine what parts that are no longer within specs.
KEEP ME UPDATED..
Sep 29, 2008 | RCA D52W19 52" Rear Projection Television
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
How do I adjust the manual convergence? I am in the settings, but my TV is not letting me adjust anything. I chose the "reset to factory" choice, but that didn't fix the red/green shadows
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My TV color has yellow, blue and red shadows n the picture.
Enter Service mode.. Press Menu -0-1-5-7 in quick succession . From there select the convergence option. You should see 3 crosshairs -Red, Blue and Green. Green is fixed but Red and blue can be moved. Align both of them with green and see if the issue resolves. If not Try moving them around and see if the problem is cleared. If not you may have the inevitable convegence IC problem and the IC needs to be replaced. Let me know if that is the case and I will give you the procedure.
Jun 11, 2010 | Mitsubishi WS-55907 55" Rear Projection...
TOshiba 36A41 CRTTV has a color problem, i can not see the color Blue.
If it got like that gradually suspect a low emission condition on the Blue gun inside the picture tube, this condition can sometimes be fixed by running a gun cleaning procedure, this is done with a crt analyser device at a repair shop. The other cause for a no blue picture could be a Blue color output that has stopped working, the loss of blue is suddendly when the color out fails, it could also be a problem in the signalprocesing circuit. I suggest having it checked by a tech because it would be something you could not check, first because of lack of equippment and second, you would need some technical troubleshooting skills to do the job.
Jan 28, 2010 | Toshiba 36A41 36" TV
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
RCA SCENIUM MODEL # D52W136DBYX1
If it's normal television, with CRT picture tube . then it's Blue gun which went off normally its a solid state circuit which can malfunction. which is located at the back neck of picture tube blue gun out put circuit a transistor or a resistance of 470 K or 390 K Ohms can blow off. or the tube base can loose contact with the blue gun pin.
Feb 06, 2018 | RCA D52W136D 52 in. TV/DVD Combo
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
