Question about Dell Dimension 4700 PC Desktop
Pre-bios problem on dell dimension
After trobbleshot procedure amber front panel still on, i removed all sdram and amber light still showing , cmos was cleared internal on board light is on
all board are removed ... all voltage from PSupply are ok.. voltage selector is ok... no beeps
  • towertech Dec 08, 2007
    question? this mother board needs any sdram installed in order
    to pass pre bios?
    Thanks .. OPKY confirming with u that no ram is required by the mobo for power on pass now is concluded tha mobo is defective, bur im wonder if i gona replace mobo, what is u recomendation
    replace MOBO with a factory (using the old PentiumChip repalcement or there is any MOBO COREDUO PACK tht fit perfect with the dell 4700 box?
Ok.. i will go for it
Thanks every body involve to TS
Any help on Apple .. count on me..
Happy Holliday
Posted on Dec 10, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello towertech
Happy Holidays
Well, it is a problem with some hardware you install, o a defective RAM, could be modem, or USB port.
also check for bad onboard power connector.
(faulty mobo)
Posted on Dec 07, 2007
  • Carlos L. Burgos
    Carlos L. Burgos Dec 08, 2007
    Good day!
    Well, you don't need any sdram for that, it could be your MOBO, or defective RAM, is a good try first, change the RAMS.
  • Carlos L. Burgos
    Carlos L. Burgos Dec 09, 2007
    hi Towertech
    Well time to change then for any of the 2, if fit right on case. but buy the Factory Mobo. Go a head, and make your gift for this christmas! hope I can help more in the future.!
    happy Holidays!
  • 37 Answers
Which dell dimension model is it
  • 1 more comment
  • paul shaw Dec 07, 2007
    is it just staying on or blinking?
    Blinking amber indicates a problem with an installed device; solid amber indicates an internal power problem
    if it is staying on it could be a device is malfunctioning or it could be something as simple as the device not sat properly. try removing and reinstalling memmory. then remove and reinstall any cards. then reinstall graphics (if not onboard) hope this helps
Dell Dimension 9200 does not boot.
remove ram and listen beep codes from the system ......still no beeps from the system .....the problem with motherboard only
Oct 15, 2012 | Dell Dimension 9200 PC Desktop
When I start the Dell Dimension 4600, it says "Enter password." But when I type the password, the cursor won't move, and no asterisks appear for each character of the password. After repeated attempts, the...
First thing I would do is to reset your CMOS by:
1) Power down.
2) Remove power cord.
3) Push power button in and hold for 15 seconds.
4) Open the case.
5) ground you self to the case for a second. (touch bare metal)
6) Remove the battery for 30 seconds.
7) Replace battery.
8) Double check all your connections and cards if any.
9) Close the case.
10) Connect power and power up.
Your diagnostic lights indicate "Other Failure". (The one on the right is amber, correct?) That could be anything. Here is a reference for your diagnostic lights:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886
Try resetting the CMOS first and comment back.
BTW, this will remove your password too, so you will have to go into the BIOS and reset. You will probably get a "Configuration change" message when you first boot up. Press F1 to go in and then do a Save & Exit.
Thanks for using Fixya.
Dec 12, 2009 | Dell Dimension 4600 PC Desktop
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Boot up problem
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
Jan 09, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension 4700 PC Desktop Logo
282 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
