Question about HP LaserJet P2015dn Printer
Error light Hi - The exclamation point in the triangle has a blinking orange light next to it - what does this mean???
  • rebeccasjhmc Dec 06, 2007
    Turning it off and on, taking otu the trays and such worked! Thanks!
  • Anonymous Apr 14, 2009
    I have that triangle exclamation error light and i have done everything and it wont go away what else can I do.
  • 58 Answers
It detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
Posted on Dec 06, 2007
The orange light on my printer is flashing next to the triangle symbol with an exclamation point in it. What does this mean and how do I fix?
Paper could be lodged in printer somewhere. Check front and rear area where paper runs through. Then unplug and try to reset
Sep 02, 2014 | HP LaserJet Office Equipment & Supplies
There is a green blinking canister next to the power reset button and next to it is an orange light with an exclamation point. What is this indicating?-
Its an information / error led . It says server hardware has encountered an error. Find device that has error and replace it if required .
You can see a similar orange color on device that has error .
Check these parts for orange color .
2: Memory
Dec 12, 2011 | IBM x3400 Server
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
Won't print, orange triangle with exclamation point
This triangle light blinking indicates that a door is open. Open the front access door completely. Close the front access door completely. Open the rear door and close it.
If this didn't fix it refer to this guide for all errors you get with this printer from HP website.
Dec 16, 2010 | HP LaserJet CP1215 Color Printer
Blinking Orange Exclamation Point on 04 4runner
Since your question is listed as a 1999 Saturn SL and a Toyota 4Runner, I will answer both:
1999 Saturn SL
Typically the orange exclamation point dash warning light is indicating a problem with your brakes, parking or hand brake. Check to ensure that your emergency brake is completely disengaged.
Check to ensure proper brake fluid level.
Otherwise this could be indicating a problem with the ABS system.
04 Toyota 4Runner
Low tire air pressure. Inflate to approximately 32 PSI should correct your problem.
I hope this helps.
May 12, 2010 | 1999 Saturn SL
Warning signal
I have a yellow triangle with a ? on my dash what does this mean
May 07, 2010 | 2006 BMW 3 Series
HP LaserJet P2015dn Printer Logo
2,127 people viewed this question
Ben Johnson
