Question about Sony DVP-NS530 DVD Player
No Audio: I play either VHS tape or DVD for about and hour or so and the Audio cuts out. This was occuring at regular intervals. I was of the belief it was an internal thermal issue as this is how it was responding at regular intervals during watching. (I am an Electrical Engineer of 30 years so I am fairly aware of electronic failings) Then the other day the Audio cut out completely so now there is no Audio at all. Does any one have a solution for this. I remember reading somewhere the 530 did have Audio issues in the early production units? Do I need to replace an Amp and heatsink it better than it currently is? Heeeellllpppp!!!!! Regards, Ron
  • empleh Dec 18, 2007
    No after about 2-3 months this symptom started appearing. It is very frustrating as you buy a component and you expect to get at least a year of trouble free operation!!! My wife and I are the only ones using it, we have no kids to gum up the works and we do not abuse things we use. This is just unacceptable lack of quality from what is suppose to be a premier electronic components manufacturer! If you here of any other possibilities I am interested in hearing about them. Thanks I will start to check for cold solder joints or non-soldered joints that could move from thermal expansion and contraction.
    Best Regards, Ron
    Problem Solver:
  • 4 Answers
it sounds like a dry joint to me. Look at the obvious places first, such as the amp as you mentioned. Anything that heats up and cools down will give problems, as I am sure you are aware. It could be a thermal issue. Has it always done it since new? thanks ST
Posted on Dec 18, 2007
  • tech123 Dec 19, 2007
    the more I think about it, it does sounds like a dry joint. The reason I think this is that if it were a faulty amp, by rights the amp should have made/ be making a hissing sound or just stop working completely. thanks ST
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Found many family TXK E-HG TC-20 tapes. What device do I need to see these?
The TC encoding usually stood for VHS-C type of tapes. These were created so that VHS type manufacturers could compete with the HI-8 type of camcorders that came out years ago. They were essentially regular VHS tapes that were shrunk down in size to allow them to build smaller camcorders.You could either play them back directly from the camera itself, or you could use the adapter that came with the camera that allowed you to play the tape back from a regular VHS VCR. The adapter was the size of a regular VHS tape, and it had a lid on the top that you would open and drop your VHS-C tape into it.
If you still have a VHS VCR you could watch the tapes using an adapter. If you do not have one you can search on the web for both the adapter and a VHS VCR if need be. Depending on the size of the city you live in there may be a conversion outfit that can take your VHS-C tapes and burn them onto DVD's for you. Prices varied quite a bit on that service so you should do a little shopping around if that is the way you want to go.
Jun 27, 2011 | Cameras
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Sony DVP-NS530 DVD Player Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
