Question about Canon imageRUNNER C3200 Color Printer
Copy Problem When printing a color copy on our Canon c3200 Imagerunner, the toner is being laid down shifted instead of laying down on top of each other. The copies look like they are in 3D. Black copies come out fine of course. We just replaced the magenta drum.
    Problem Solver:
  • 6 Answers
This could be two things first, the transfer belt is slipping. It can be cleaned on the inside of the belt and the rubber drive roller. second, the laser units need to be timed, its not hard to do but a service tech will need to do both. it should be running great. the 3200 is a great box
Posted on Dec 30, 2007
Why is the print blurry
If black & white copies are ok you can probably bet it is an issue with the ITB (transfer belt assy) or a color registration issue. If black & white copies are also blurry.....could be a variety of issues. If it only happens when you copy but printing is ok from the computer......scanner is at fault.
Jul 31, 2012 | Canon imageRUNNER C3200 Copier
E000020 01b0
Yellow Drum Cartridge or bad toner. If your using generic toner it can cause this code. If generic toner is used drum cartridge unit will have to be replaced and Canon Genuine toner used instead. Yellow seems to be more suseptable to this than the other colors for some reason.
Nov 25, 2011 | Canon imageRUNNER C3200 Copier
Getting lines about 1-2 inches down the side have a image 2200 located in Wheeling Wv. area code 26003 can not find a local dealer listed to look at it
are the lines also on printed image or only on copy?
If only on copy - clean the copy glass.Eaven the smallest dirt on copy glass could give you the problem.
if on printed too, it could be drum unit.
For local dealer i cant help you, but if its drum unit you can change it on your own.
To check drum:
open front cover, realese left blu handle, realese the toner handle, unscrew grey screw ( screw is unscrewd by hand ) on drum unit, and pull it out.
If there is any lines on drum replace it.
The drum goes aprox. 60-70000 copies.
If the drum is ok, also check fixing film - for thath call/find service.
hope that helped
Jul 02, 2010 | Canon imageRUNNER C3200 Color Printer
Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
Problem with printer
Have you tried a new magenta cartidge. I think it has run out, that'swhy you can only print black
Mar 23, 2009 | Canon imageRUNNER C3200 Color Printer
Copy not good
under user mode there must be color or gradation adjustment, i belive under printer prop.
How many copies do you have?
After 100000 copies you will need to change developing units, and clean drum sensor, or replace drum.Call service.
Dec 17, 2008 | Canon imageRUNNER C3200 Color Printer
C3200 COLOR PROBLEM
3 possibility 1-your secondary transfer is dirty or needs changing 2- your primary transfer sheed is damage or your fixing assy. is damage go with number 1 first try cleaning with a clean dry rag then blow away any lint. for service mode press and hold additional function at same time hold down 2 and 8 then add function again
Nov 19, 2008 | Canon imageRUNNER C3200 Copier
Canon Imagerunner c3200 copier problem
Sound to me like a drum problem, try replacing it and it should work after u do..
Nov 28, 2007 | Canon imageRUNNER C3200 Color Printer
Canon IRc3200 pdf printing issue
base on my experience, that kind of problem occur when some programs on the driver was skipped during the installation. you can try to unstall the driver then reboot and then reinstall it again. this might solve your problem.
Sep 18, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Color Printer Logo
93 people viewed this question
old marine
old marine
