Jaguar X300 battery has gone dead, and boot wont open. The key is not being accpeted. What can I do? Is there a way to open the boot - or can I charge the battery any other way?
there is a battery pos post under the bonnet/hood but you should be able to open the boot/trunk using the manual key access in the boot /trunk plinth unless its siezed cos it has not been used try a bit of wd40 and work the key gently till it gets free
the wiring around the trunk/boot hinge may be broken/opencircuit. the security system thnks the trunk/boot is open use the manual key to get in to the trunk and repair the wiring
If the locks are working whilst you are driving then more and likely it is the actual door lock assy that is bad. the solenoid go bad and can cause erratic operation. But unfortunately they are only available with the whole door lock/latch assy.
I would disconnect the drivers and see if the problem still exists. JPTCAT
the battery has gone dead you can not open the boot/trunk with the electrical system but you should be able to get to the battery by using the key in the lock on the outside of the the trunk its either in the xj badge or the number plate illumination holder. if you can open the engine compartment there is battery pos power points so you can jumpstart/power up the car
battery discharged, key won't open boot
