Question about Sony Handycam CCD-TRV318 Camcorder
Cannot playback recorded video
Hi, hope you can help!
I cannot play back my recorded footage - when i switch on in player mode i get the first few seconds and then it automatically switches off with a beeping noise, a little yellow underlined triangle flashing on the screen and C31:23 in the top right hand corner. I dont think its the battery as i've tried the battery on another video and it works perfectly well and is charged.. any ideas what it could be and how i can fix it? (have tried resetting).
would be very grateful to hear from you -
Kind Regards,
Vicki Gontier
  • Anonymous Jan 15, 2008
    I also have the same problem, except for the fact that I don't know where the heck the Reel Sensor is ???
  • 169 Answers
Reel sensor is the problem of your camera... sometimes it is a poor connection of the sensor to the socket at the main board..clean the contact of the wiring using a pencil eraser and also check the pitch roller of the mechanical if it is install cause it might be loose at it post cause of the lock has been broken already...
Posted on Dec 09, 2007
How play the recorded video?
The controls for playback are on the touch screen once the camera is switched from record mode to playback mode, if the camcorder isnt playing back then you might ned to have the unit serviced, could be a bad video head assy. I hope this helps.
Sep 05, 2010 | Sony DCR-HC30E MiniDV Camcorder
Malfunctioning One-Touch Navigation & Joystick Control
You can try first a reset from menu, then , if firmware is available you can reinstall firmware.
Sep 11, 2008 | Panasonic PV-GS300 Mini DV Digital...
No picture or sound on playback
Hi, All sorted. I purchased a head cleaner and played it for 10 seconds. The camera now works as good a s new. Hope this will help others with a similar problem. John
Jun 04, 2009 | Sony Handycam DCR-TRV110 Camcorder
Can play video, but can't record
Have you tried to record your channels with the converter switch set to antenna?
In otherwords;
Step 1. With your converter switch set to converter mode select the Direct tv channel you wish to record.
Step 2. With your converter switch set to antenna press the record button on your DVD Recorder.
Step 3. Switch your converter switch to converter mode.
I hope that you find this solution helpful.
Feb 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Playback STD Locked Playback is Restricted message
the tape most likely has the lock switched on, it's secured so no one can even view it, why it happend, beats me, look at the bottom of the tape, if it has the lock switch, and is pushed up to "lock" push it back down, if  that doesn't work than I'm not sure, sorry.
hope this helped- snowsurfer58
Nov 05, 2008 | Canon XH A1 Mini DV Digital Camcorder
Sony DCR-HC 36E Bands of old video & pixellation
well, first a few things I want to point out to you.
-fixya is no a job for experts.
-I can't be on guard 24/7
The video heads may be dirty use a cleaning Casette to see if things improve
Aug 25, 2008 | Cameras
Trying to play off-camera stored video, when replaced onto SD card in camera
Did you change the file name on the original video? Are you able to put the video back onto the camera? If you changed the file name, you can't put it back onto the camera. It also needs to be in AVI format which is the video format that the camera records in.
Hope this helps!
May 28, 2008 | Canon PowerShot S5 IS Digital Camera
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Sony Camcorder playback problem
mechanical alignment! try to record for a minute and playback the result on another player/recorder, not on your camera, if the playback is not okay then your camera needs alignment, you need pro fix. You said that you've done manual cleaning already, maybe you dis aligned the mechanical parts accidentally, applying too much force on the mechanical parts of your small unit tends to bend, dislocate or move these parts out of alignment. defective videohead will never playback good video, and you said that it seems to correct only a few minutes of playback.
Sep 13, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
Check out: Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
Sony Handycam CCD-TRV318 Camcorder Logo
160 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
