Question about Mitsubishi VS-5043 50" Rear Projection Television
VS-5043 Has picture initially then has a giant black box in the middle.
Whenever I turn my set on, the picture and sound come on and after a second, you can only see the outside of the picture, almost as if there is a blank box in the middle. If I turn the channels, I can see the full picture again and then it reverts to having only the sides if the picture showing.....any ideas ?
    President:
  • 4,402 Answers
These TVsVS-5043 Has picture initially then has a giant bla - 2.gif are notorious for bad capacitors at that age. Even if only one or two may be causing the problem, the whole set may need to be re-capped - replacing every electrolytic capacitor that has gone bad, may go bad, or is likely to go bad in the future. There may be a few hundred parts to change. This is a VZ3 chassis....notorious for cracked solder connections on the yoke plugs. Look at each yoke on the 3 CRT necks , you'll see a Molex plug on each yoke. The top two connections are for the vertical winding. There is a plastic tab that hinders easy soldering of these....carefully clip it off with a good pair of ****. You can then access the top 2 solder connections.
Posted on Dec 15, 2007
Mitsubishi vs 5043 no picture
have the tubes checked out you may have a loose connection
Jul 15, 2008 | Mitsubishi VS-5043 50" Rear Projection...
TV turns on, but no picture or sound from any source
You need to have the Liquid chaged in the Projection tubes & /or Rear lamp replaced
Jun 24, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
Mar 27, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Tv with power but no picture or sound...
you have no deflection and don't leave the dot on to long it will burn the crt's.
Aug 11, 2007 | Mitsubishi VS-5043/44 50" Rear Projection...
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Black horizontal lines on mitsubishi VS-5043
Is the noise in all inputs (line, tumer) ? If it is in the tuner alone, check the coax lug to see if you knocked it loose. This could be the problem. Check you picture with a DVD player on the Video input. Let me know what you find.
Jul 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
