I have a GE front load dryer MOD#DBVH510EHOWW..SER#GM777444 when i try to start it it just hums and the drum dosent spin... i can spin the drum by hand if it is empty...if there is laundry in it and i start the drum by hand the motor sounds fine BUT the drum stops spinning
Have you checked the drying drum to see if it spins freely? Open the door and verify it spins freely. if it does then the motor may just be in a bad spot. usually after spinning the drum a turn or two it will get it running. it humms and clicks because of the motor not turning and trips an thermal overload switch and you have to wait for it to reset. Now if the drum dosent turn then you have a problem with drum rollers or something stuck in the way of the drum.
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
The roller for the belt tensioner has a bad bearing. replace that item as well as the belt The start button is stuck to the start position so replace that as well The top & front panel will need to come off to repair both items
The most likely cause is the front drum supports. There are 3 or 4 teflon strips (about a half inch wide and 2 inches long) on the top of the front panel that the dryer drum glides on. When these wear down, the drum can scrape on the plastic that holds them or on the metal frame around the door frame. Another possibility is if the drum touches the dryer exhaust vent pipe, most often only if the dryer is vented out the bottom of the dryer and the vent pipe has shifted up just a bit, allowing it to contact a spot on the drum with each revolution.
