SOURCE: 8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
SOURCE: Sharp VL-E610
Get a firewire (IEEE-1394) cable insteaad of trying to use USB. Make sure that both camera and computer have firewire ports. Set camera to Tape/VCR or whatever setting you use when you playback your tape on your camcorder. Just leave it on that setting, don't hit "Play" or anything. Make sure that you have rewinded to the spot where you want it to start (a few seconds before, actually).
If you have WIndows Vista, you don't need drivers. The built-in Windows Photo Gallery will recognize it and will ask you if you want to transfer the tape. It will walk you through the whole process, if you want to transfer the whole tape or only parts of it. If you don't have Vista, you might try downloading Windows Live Photo Gallery but I don't know if it has the same functionality.
SOURCE: transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
SOURCE: Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
