Question about GoVideo DV2130 DVD Player/VCR
DV2130 Firmware upgrade.
I downloaded and burnt to CD the firmware upgrade
When I insert the CD w/ upgrade I get the message
"firmware upgrade"
old ver 2.030827.02GVI
new ver 3.040421.02GVI
press enter.
I press enter, get the message "loading" an it just sits there.
I have walked away an let it alone for over and hour.
When I come back nothing has changed, same message.
The Customer service # 1-800-736-7679 no longer works.
Any ideas?
Does this upgrade really help, if you can get it to work?
Or should I just let well enough alone.
Thanks,
Where did you get this firmware?
Posted on Mar 10, 2008
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Pontus Pac7002 firmwar upgrade
please connect the [player t system and click firmware update
Mar 23, 2008 | Pontus PAC7002 CD Player
D-Link DI-514 Router Firmware Upgrade Error Message
This is an old post, but just in case someone else needs this...
The dlink website for the Di 514 rev B version actually links to the rev C versions' firmware. I got the same error.
browse to here ftp://ftp.dlink.com/Gateway and grab the right version for your rev B device.
Best,
Kevin
Oct 04, 2012 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
During initial setup at the end i keep getting an error message saying that my router isnt connected properly. im running from a router/modem combination in my basement.
Are you trying to set up the router using CD ?
Sometimes the CD does not work.
You can set up the router manually without CD.
Now! the first thing is that you have WRT160N router. This router has issues with the firmware. I will advise you to upgrade the firmware of the router. Download the new firmware of the router from the web site and upgrade the firmware. REset the router and reconfigure the router.
You will need to open the set up page of the router to upgrade the firmware.
Apr 19, 2010 | Linksys WRT160N Wireless Router
Numark HDX system needs upgrade: Insert upgrade cd?
You just need to type Numark Hdx in your search engine or on numark's website, and they have the download for the firmware update. Download and burn to disk. Turn on your deck holding the eject button until it ask for you to insert the disk you burned. Go thru the prompts and let it install firmware *NOTE DO NOT TURN OFF DECK* or you will ruin it.
Jun 12, 2009 | Numark HDX Turntable
Samsung 22x Super Writemaster SH-S223F not reading any disc
im having the same problem with this drive and samsung has not helped at all. i cant even upgrade the firmware because the automatic upgrade program that upgrades the firmware comes up with a warning window right off the start, but the window is the wrong size for the text and you cant quite see the OK button or click on it to continue. just a reflection of samsung quality. nothing but garbage. to me samsung is just a big scam. once they have your money, thats it , 0 support. oh well you got me again samsung, my fault. ill just throw this drive on the pile of samsung.
Nov 17, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Will not initalize any disk.
A firmware upgrade is available here:
http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Jan 15, 2008 | Lite On LVW-5005 DVD Recorder
GoVideo DV2130 DVD Player/VCR Logo
409 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
