Question about Flat Panel Televisions
HI, I have a vizio L32HDTV10A. 80% OF THE SCREEN goes out. it will work again for 10min the next day. SOUND is good, 20% at the top of the screen is good. Has anyone fix this problem? THANKS MUCH..
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
SOURCE: 42' polaroid tv wont show screen still
it is a manufacturing defect. Mine had it. My advice is to never buy polaroid tvs. but anyway, here is a link on how to fix the problem...
Posted on Dec 29, 2008
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
Have you tryed unplugging it, waiting about a minute and plug back in. May happen again, but try each time. Seems to solve the problem for a while.
Posted on Jun 09, 2009
  • 563 Answers
SOURCE: Vizio VX32L The screen goes white,no response from buttons
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 28, 2009
  • 6 Answers
SOURCE: Left Side of Screen goes semi dark
That Probaly Means Your ******* Kid Jerked Off All Over The Monitor *******
Posted on Jan 31, 2010
0 characters
1 Points
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
I have 42 vizio hd lcd flat t.v. and when you turn it on the picture go's out and yet you can hear sound. I have to turn it off then on again all day. just watch t.v. im tired of it
Sounds like a backlight problem. Next time the picture goes out, try using a strong light next to the screen. Do you see a faint image? That means your lamps have turned off. May be bad power supply to them, an inverter board problem or a bad lamp. Unless you are a tech, it's a repair shop issue.
Mar 10, 2010 | Vizio L37 Television
Vizio TV won't turn on
The power supply will be the first place to look, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Please post back what you find.
Dec 23, 2009 | Vizio L32 32 in. LCD HDTV
The screen whent white with a few lines across the screen.
The problem can be in the LCD CONTROLLER (T-CON) board. Check to see if you have voltage feeding the board or it may have blown surface mounted fuse on the board.
Dec 17, 2009 | Vizio L32 32 in. LCD HDTV
Set made a sound as if it lost power, now screen is blank and does not respond to any commands
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Here is the place to get parts for L32HDTV10A:
Dec 07, 2009 | Vizio L32 32 in. LCD HDTV
Jun 07, 2009 | Vizio L32 32 in. LCD HDTV
Viewsonic n3246w Screen goes blank
It's the LCD panel assy failure. Most likely the high voltage Inverter board failed.
Feb 01, 2008 | Flat Panel Televisions
Flat Panel Televisions Logo
193 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
