Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Install prob Just recieved ADSL AlcatelSpeeedTouch 516 modem. Hooked it up- works fine. Added a WL 520gc wireless router, powers up, runs the install, but not sending or receiving. While running set up with adaptor installed, iIt gets to 99% of the last step and then says the adaptors show problems and I should run it wired. Wired also gets no response. Tried redoing the install, with ony the wired installed, but also nothing!. Thanks for the help! Oh! I'm not very good with PC's so please keep the responses simple
  • Argggg Jan 09, 2008
    Hi Pasha,
    sotty to respond so late, your response got buried in other emails. I have since found a man who could configure the wireless. Unfortunately, it only runs on one comnputer at a time.
    If you have any thoughts on this ...
    Thanks
    George Murray
  • 556 Answers
I suspect these devices by default may be set to either the same IP address or exist on the same subnet. If you know how to configure the devices you can check. Possibly you can connect a computer to each (when not router and modem are not connected to each other) and issue use the open the DOS or command prompt type ipconfig and press enter to get the default gateway address for each device and report the contents back here. Otherwise you may need someone to lead you through those checks and reconfigure the devices as appropriate.
As a new owner of a wireless router you may also want to consider this as you are installing it.
for general wireless security see
http://www.fixya.com/support/t281214-wir...
Posted on Dec 06, 2007
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Cannot connect to internet
Make the Ip address similary to the router, example 192.168.1.25 should work.
SUbnet mask will then fill in automaticaly, just leave it
then Default gateway will be the routers IP. 192.168.1.1
the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell.
good luck
Dec 25, 2008 | Computers & Internet
Asus WL-520GC wireless not working....
hi buddy!
first you configure the router to the modem ok
by typing the 192.168.1.1 and follow the instruction ok
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 22, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can´t access 192.168.1.1 (router admin page)
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Apr 19, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can not get my adsl modem to connect through ASUS wireless router
it could be the modem and the router has the same ip address. the asus router has an ip of 192.168.1.1, check if the dynalink modem has an ip of 192.168.1.x. if so, change the router's ip to 192.168.x.x (e.g. 192.168.2.1) then see if you'll be able to connect to the internet while the modem is connected to the wan port of the router
Apr 02, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
DEFAULT ADDRESS
The default IP address is 192.168.1.1
The manual is here:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=WL-520gC
Have you used the setup CD?
Nov 01, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Set up wireless router and modem Linksyss
It is not hard at all, but its alot of typing.
First have you tried following the manual to set it up?
Oct 22, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
93 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
