Question about Clarion EQS746 Equalizer - 7-Band In-Dash Rotary Equalizer with Subwoofer Crossover Auxiliary Input Car Equalizer
How can i get my power to my EQ?
The bass from my subs seem to drain all the power from my equalizer. i have a capacitor hooked up but it doesnt seems like its helping any. when my bass comes on the lights from my EQ dim and the whole thing turns off for about a half second if i have my radio loud is there anything i can do to get more power to it, or is there a problem other than that?
Get a higher fared capacitor
Posted on Mar 15, 2010
  • 65 Answers
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Posted on Dec 07, 2007
How do I hook a bsr eq-1 equalizer to a Yamaha av receiver rxv573
Seems like it should be , audio out to the eq. Then out of the eq to your sound source, ( speakers )
Apr 22, 2015 | Yamaha Audio Players & Recorders
Friend gave it to me unsure how to hook it up
is there an in out patch on your bass amp?
Jan 15, 2014 | DBX 1231 Home Equalizer
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
How to hook up 18"
SO I am going to give you more of a signal layout from the turntables (or whatever you use to DJ) to the speakers.
Turn tables-> Mixer-> Eq-> Amp-> Sub and other speakers.
The part that I am not understanding is why do you need the QSC amp if you have a powered sub? The powered part of that means that there is a built in amp, which eliminates the need for the QSC amp unless you are sending that sound to main (non sub) speakers.
Hope that helps!
May 03, 2011 | Audio Players & Recorders
How to wire it to make the bass cuts off when offing the eq
This unit has a separate EQ band for the subwoofer-- you'd connect the sub-out from your CD player to the sub input on the EQ, and the sub-out from the EQ into the input on the sub amp.
The "sub" slider would then adjust the sub volume.
If your CD player doesn't have a sub-out, and you are just using one of the regular front/rear outputs to feed the sub amp, then the sub volume will follow the other sliders toward the left side of the unit, which is less desirable.
Feb 13, 2011 | BOSS AUDIO SYSTEMS AVA1204 7Band Car...
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
I cant seem to hook my pioneer gr 470 equalizer to my pioneer receiver ( vsx-403) what is the proper connection sequence?
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Sep 02, 2010 | Pioneer GR-470 Home Equalizer
How to make the eq so that speakers play nice and loud so the subs don't over power them?
On an eq, the level farthest left is for bass. Then all the way right is for trebble.
Oct 01, 2009 | Car Audio & Video
JL Audio 1000/1 hook up to alpine type x
it is all up to the user, you can start by turning the input up slightly, I would not go over halfway because it usually starts to distort, then the bass boost up till they distort a little then back down a quarter turn.
Mar 10, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Car Audio & Video Logo
370 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
