Ingersoll Rand  Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
Problem for Ingersoll Rand Type 30 Fully Packaged Ir Electric...
Motor pulley for an old Ingersoll Rand type 30 compressor
By rjulian on Sep 01, 2009
I have an old Ingersoll Rand Type 30 horizontal tank compressor that was given to me by my father-in-law. He jury-rigged a motor to drive it as it had no motor when he got it. The compressor has a 3 groove pulley but the motor was set up with 2 aluminum pulleys which lined up with the two outer grooves on the compressor pulley. This worked well for about 5 years but I continuously had issues keeping the belts tight enough to prevent slipping and the aluminum pulleys finally gave out. The pulleys were approx. 2.25” in OD. I have found 3 groove cast iron pulleys that will fit my motor but none that small; the smallest OD available is 3.75”. In reading another person’s solution here for their compressor motor pulley problem, I’m wondering if 3.75” may be too small for the intended design of the compressor…?
Here are the specs: The compressor is an Ingersoll Rand Type 30, size 5 & 3X31/2, Model 253, S/N 30T 115---
It was originally built/sold by Berg – DiMare & Berg Pumps, Air Compressors, Motors located (at the time) on Haverhill Street in Boston, Mass.
The motor on it (not original) is a capacitor start 5hp, 3450 RPM, 230 Volt with a 5/8” shaft.
Since it worked for so long with the small 2.25” pulleys, I’m pretty sure it’ll work fine with the 3.75” cast iron one as well, but I kind of wanted a better fit as to the size it should have.
Comments:
Sep 01, 2009
- I forgot to mention that the compressor's pulley is 17.5" in OD...
Best Solution
posted on Sep 01, 2009
Very Helpful)
wilson59
Rank: Guru
Rating: 87%, 180 votes
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for the info; I'll contact them and go from there. " - rjulian
Solution #2
posted on Nov 25, 2009
Not Rated)
compman66
Rank: Master
Rating: 0%, 0 votes
Think you have a problem with to small of a pulley @ 2.25 O.D. to pull that pump using a 3600 rpm motor, If you contact a I.R. distributor about that pump they should be able to tell you the recommended motor H.P. , rpm, and pulley sizes it should run at. Trust me, don't start guessing, will spend a lot of money quick if you are wrong!
Was this helpful?
Yes
No
Solution #3
posted on Sep 08, 2009
Not Rated)
youdoit
Rank: Guru
Rating: 93%, 475 votes
I AM SORRY I DID NOT SEE THIS PROBLEM COME UP ,YOU SHOULD HAVE ASKED FOR ME . HAVE YOU GOTTEN IT SORTED OUT ? IF NOT COME BACK TO ME IT WONT TAKE AMINUTE OR SO TOWORK IT OUT. TO GET IT EXACT LOOK ON THE COMPRESSOR PLATE IT SHOULD GIVE YOU A MAX RPM THAT IS ALL THAT INEED THAT ISN`T STATED..I`LL GIVE YOU A DIRECT EMAIL ADDRESSIF NEEDED ONCE AGAIN I`M SORRY I MISSED THE ORIGINAL POST kklittleton@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Ingersoll Rand Type 30 Fully
Questions and Unsolved Problems for Ingersoll Rand Type 30 Fully
Do you recommend Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage ?
Answer
Answer
how do you charge powercraft 12v power stationlost manual,do all switchs have to be on or off. when... (More)
Answer
I have an upright 3hp 20 gal pit bull compressor that the tree where the hose and gauges hook too... (More)
Answer
Compressor sounds like it's running under a large load and really slow. Blows circuit breaker... (More)
Answer
how do you change the temp from 75 degrees to 80 degrees?
Answer
looking for an owners manual for an IR T30 Model 2475. 2 stage, 80 gal vertical.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ingersoll Rand Type 30 Fully...:
Top Air Compressor Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Compressor Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
