Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
How to install the water hose
How would i install the water hose to the back of the refrig and into my main water line
    Sergeant:
    Champion:
  • 262 Answers
You have to have a ice maker install kit that you you can buy at any hardware store if you dont have a water source in the wall behind the ref.(if you have it in the wall you will need a ice maker hose only) but if you have to buy the kit it has a tap valve that you put on the COLD water supply under the sink if you have pvc, poly or quest you will need a special tee. route tubing so it wont interfere with foot traffic to behind the ref. the kit will have a brass nut and a flange put the nut over the tubing then put flange inside the end of the tubing the locate water inlet valve on ref.screw nut onto capped end of valve (remove cap first) then turn on the water and bleed water through ref.using water dispenser on the door until you get water then enjoy. oh kit has instructions in it also good luck
Posted on Dec 07, 2007
Water not working but still makes ice
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR49X10173 to keep this from happening again ( comes with instructions ) .
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Tip
GE / Hotpoint S xS Refrig: Will not dispense water
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
on May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser stopped dispensing.
If the water line in the door is frozen , GE has a dispensor heater which comes with instructions to install . Pt # WR49X10173 .
May 21, 2010 | Hotpoint HSS25GFP Side by Side...
The water supply tube in the back of the refrig pops off when the refrig attempts to make ice. There is no clog in the supply line. How do I check the attachment that is attached to the back of the...
if you think it's clogged it's probbaly iced up,use a hair dryer and melt it out,see if you can put a hose clamp around the hose to hold it in place,does any water make it into the ice maker?see if you can stick a straw oonto the piece the tube slides onto and see if you can blow through it to see if it's clogged or it's just the water pressure blowing the line off,might just need to be attached better
Jan 27, 2010 | Amana ABB1927DE Bottom Freezer...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Why am I not getting any water from door dispenser for model GSS23KGSA BB
Pull refrig out , and remove the back panel . At the water valve (piece the wall water line connects to , push up on the white ring and pull the LARGER line from the valve . Activate the water dispensor and see if water comes out of the valve . If no water , replace the complete water valve . If water comes out , reinstall the hose by pushing back into valve , and remount valve and rear panel . Push refrig back into place . Remove the bottom kick plate and disconnect the water line about 6" under front , from the coupling (pushing in the ring and pulling hose ). Press for water again . If no water comes out , probably frozen resevoir behind the refrig crispers , so turn refrig temp slightly warmer for a few days , to unthaw (or use hairdryer) . If water shoots out from hose , then water line inside door is frozen . This would be a more difficult procedure to follow . You can try adjusting freezer temp slightly warmer for a few days to see if it will thaw . If it doesn't thaw , come back to this thread with " water in door frozen " and myself or another expert will be glad to help you .
Sep 09, 2009 | Refrigerators
I can not get water nor ice side by side refrig
Hello...the water valves might be the problem, seeing how you've checked the water line and water flows out. I had the same problem. No ice, no water. The water valve was defective. Hope this helps you out. :)
Feb 12, 2009 | Frigidaire FRS26R4A Side by Side...
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Fridg
water line in freezer door is froze up. Call GE customer service to see if your ref. has a service bulletin.
Jan 05, 2008 | Hotpoint HSS25GFP Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
942 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
