New out of the box Charmglow fire stick. First time I used it, it maintained a blue flame, heated the screen around the burner to a cherry red. Worked great. Second time I used it the flames were yellow and huge. This is making a sooty mess on the deflector. It doesnt heat the screen or radiate as much heat down like before.
Is this a problem or is this normal??
Comments:
Sep 01, 2009
- Called the manufacturer and they're sending a new head unit. Thanks for the help!
It is a problem take it back to the store to get it replaced there is a problem with gas getting to the jets and it could be several things, if they can tell you whats wrong or they will replace it free of vcharge hope this helps, if you have any problems let me know and I will try to help. to do that clcik on the link you will recieve for this post.
Avid101
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and...
(More)
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and flame works, but no heat. Unit only worked for a few times, then this happened. How can I troubleshoot to see what part needs to be replaced. Thanks.
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but...
(More)
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but neither pump works. Both fuses are good. Electrician just checked them. No reset on pumps. Any ideas?
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve...
(More)
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve problem ?
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with...
(More)
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with a slight hissing noice but the smell of propane is very slight. The propane tank is full and functional and I have cleaned out the top section where the gas is emitted. Has the regulator gone bad or is there another issue?
