Question about Garmin eTrex Vista GPS Receiver
Worn out rubber
Where can i get new rubber for my vista.
  • nelsonh May 26, 2008
    the rubber band arround my etrex vista HCx unglued. Is there any way to find a replace band to fix this problem.
    thank you
  • hriva Jan 23, 2009
    same one...
  • 3 Answers
G/night fellas,I'm experiencing knocking noise beneath when driving on rough surfaces but not during smooth road.Engine sounds good and look new.Whats the possible cause of the knocking noise?
loose / broken exhaust mounts/muffler mount rubbers
loose worn shock absorber rubbers
worn ball joints /. suspension rubbers
worn stabilizer bar mounts
Mar 08, 2016 | Cars & Trucks
Luxline 160e. Why does electric window keep coming out of rubber guide?
not aligned correctly or the rubber is too new put some armor all on it, or check to make sure the rubber is seated I there good, if it is new its just new and needs to be used a bit if it is not new its worn out replace the guide.
Oct 14, 2015 | Honda Cars & Trucks
Squeaking noise while driving on rough of uneven road
check for dry/worn rubbers on the suspension, stabiliser bar, shocky rubbers , dry/worn ball joints
if you have fitted polyurethane bushes instead of rubber , they will be loose on the suspension bolts.
Aug 10, 2015 | Cars & Trucks
Rubber worn around the sunroof window is fine
These usually have a drain in the unit which may be clogged. If it is just the rubber worn you might try using black RTV to make a patch, as a cheap fix, or just replace the worn part.
Dec 12, 2014 | 2002 Toyota RAV4
Brand new just tookout of container and wont stick to windshield
Sometimes the rubber plunger plastic/rubber new is not worn in yet, take rubber plunger part off, soak in warm water for a few minutes, then bend it in just a few times, put a dab og saliva on it stick it on and push lever back firm, twist suction cup some before putting lever down to secure it. If this helped, please rate with 4 thumbs , to help me and others. Thanks mike from fixya
Jun 16, 2011 | GPS
Minolta ep 2152 shows p.c. new cartridge in it. i see no paper stuck.
check the pick up rubber maybe its dirty or the rubber is worn out
Nov 19, 2010 | Minolta Office Equipment & Supplies
Worn suspension rubbers
They are replaceable. New suspension rubber grommets will make a world of difference in how you Land Rover handles and drives.
May 18, 2010 | 1995 Land Rover Discovery
Kenmore sewing machine (new) - bobbin threading post is not spinning to thread the bobbin - any solution?
If the bobbin winder is not turning after pushing it on it will either be that there is some oily rsidue on the winder rubber, the winder rubber is worn on one side although if the machine is new it is very unlikely, the winder rubber is not connecting with the balance wheel which means an adjustment and that will mean getting inside the machine which is not easy.
Oct 24, 2009 | Kenmore 15343
Doesn't work. I have installed new batteries that I know are good.
Under the batteries there a screw take that out that screw take the remote aparts check all the rubbers films and knobs in the board,betwen the rubber see any rub out or worn out rubbers knobs,that why the remote not working,clean it with some alchol,on the circuit board might solve prob.if all rubbers knobs,films is good.
Oct 14, 2009 | Samsung Bn59-00673a Remote Control
Could you tell me if the rubbers that fit top and bottem are the
No and if they are worn out you should replace the shocks as they are worn out.To be sure you can push down on the fender where it is solid shove down quickly and let go. Does the car bounce more than once? if yes the shocks are bad. If they are not bad you can buy new rubber bushings at auto parts stores like Nappa.
Sep 28, 2009 | 1992 Nissan NX
Garmin eTrex Vista GPS Receiver Logo
185 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
