HDtv picture and av reciever sound do not match
I have an HDTV hooked up to a direct tv hd dvr via HDMI outout, my yamaha av reciever is hooked up to the hd dvr via optical output. The sound and picture do not match, there is a slight delay. Thanks!
  • dlmcon57 Aug 10, 2008
    SOUND AND PICTURE ARE NOT IN SYNC. HOW CAN THAT BE ADJUSTED? I WENT THRU THE GUIDE THAT CAME WITH THE TV AND THAT PROBLEM IS NOT ADDRESSED. IAM USING AN HDMI CABLE FROM MY SATELLITE BOX TO THE TV.
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Posted on Dec 16, 2009
I have a RCA RT2906 surround sound reciever. I have an Insignia NS-32L550A1 HDTV. I also have a PS3 and a Comcast HD DVR. I've hooked all of these up according to the manual (with HDMI cables), and I...
You should have your signal in to your Comcast, then HDMI out to Sat in on your receiver. I haven't looked but I'm guessing you have multiple HDMI in on your receiver, but remember, you only have one HDMI out from receiver which would go to tv. What happens if you hook HDMI directly friom Comcast out to HDTV in.If you still have a delay there must be some sort of adjustment on your tv. When you plug into tv, Is it a default screen you can't change or, can you check say video 1, etc.? How many HDMI inputs do you have on your tv? Let me know through "add a comment"
Dave
Mar 28, 2011 | Audio Players & Recorders
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
I am hooked up to At&t uverse through a DVR. It works fine except when HD light on DVR indicater comes on then TV and sound go blank. Could it be that this TV doesn't support HD?
Some DLP tvs support HD some don't.Easy to find out.Ur tv have any HDMI ports for the HDMI cables to hook up in?Yes,it support HD,no HDMI ports,than it dosen't support HD.
Oct 26, 2010 | Sony KP-53HS30 53" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
I have model number AVR587 Dennon receiver which worked fine with my nonHDTV; however, I just purchased a new HDTV and since the receiver model does not have HDTV the audio goes through the DVR. The...
it sounds as if your using HDMI out of the DVR to the TV which is fine but the better way to do this is to use the Component connections (red, Green, Blue) plus optical or coaxial from the DVR to the reciever and Component connections (red, Green, Blue) out of the reciever to the tv
Jun 27, 2009 | Denon Audio Players & Recorders
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
718 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
