Question about Microsoft Xbox 360 Console
How do i connect to xbox live with a router
360 xbox brand new
  • 4 more comments
  • Anonymous Dec 19, 2007
    my xbox is saying update or go to xbox.com
  • Anonymous Jun 15, 2008
    I have an xbox 360, a computer and an ethernet cable, I tried connecting everything and my xbox wouldn't recognize that it was connected
  • wellrats Jan 14, 2009
    i dont know what to do
  • Anonymous Jan 19, 2009
    how do i connect to xbox live without a gateway and just a router and a modem?
  • Anonymous Feb 15, 2009
    can"t figure out how to get set up to live
  • Anonymous May 02, 2009
    i needed to know how to find the gateway address not this
  • 7 Answers
OK well there is a much easier way of doing so, if you have a laptop. You can go to
  1. GO to my network places
  2. Click view network connections
  3. Click on the wireless connection bar
  4. Click on properties
  5. Go to the advanced tab
  6. Check the 2 boxes
  7. Press ok
Now your laptop will chare the connection with other devies. So you can hook the 360 directly to the laptop and it will work.
Posted on Jun 17, 2008
    Problem Solver:
  • 12 Answers
Shared connection with a modem and a router
1. Turn the modem off, and then turn it back on. Then turn the router power off, and then turn it back on. This is also known as power cycling the modem and the router.
Power cycle the modem first, and then power cycle the router. To power cycle these devices, you should follow your manufacturer’s specific instructions. Here are some general steps:
a. Remove the power supply from your device.
b. Leave the device unplugged for 15 to 30 seconds.
c. Reattach the power supply to the modem by following the device manufacturer’s instructions.
d. Wait several minutes for the device to start and to establish a connection with your broadband provider.
e. Verify that the modem shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
2. If power cycling your modem and router does not resolve the problem, try connecting the Xbox 360 console to Xbox LIVE by using the modem only. This eliminates any configuration problems on the router. If this setup works without the router, there is probably a configuration issue with the router. See the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
3. Verify that your router's Dynamic Host Configuration Protocol (DHCP) service has been enabled. DHCP enables the router to assign IP addresses to the computers and consoles on your network when you go online. If you need help with this, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
4. If you manually entered an IP address, gateway, subnet mask and/or DNS servers in the Network Settings area of the Xbox Dashboard , verify that it they are correct. At this point, you can also set your IP settings to Automatic. To do this, follow these steps:
a. Move to the System area.
b. Select Network Settings.
c. Select Automatic.
5. If your ISP requires Point-to-Point Protocol over Ethernet (PPPoE) settings, try connecting to only the modem after you enter these settings in the Network Settings area of the Xbox Dashboard. Network Settings area of the Xbox Dashboard.
Note Some ISPs may require Point-to-Point Protocol over Ethernet (http://www.xbox.com/en-US/support/connecttolive/xbox360/resources/glossary.htm#ethernet) (PPPoE) settings, This means that you may need settings such as a username and password in order to gain access to your ISP’s network. If you are unsure whether you have to enter these settings, please contact your ISP support group. At this point, if you can connect directly to the modem, see your router documentation to configure the PPPoE settings correctly on the router.
6. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
If this works, there may be a configuration issue on the router’s Dynamic Host Configuration Protocol (DHCP) server. DHCP enables the router to assign temporary IP addresses to the computers on your network when you go online. If you need help with understanding DHCP or the configuration, see the manufacturer’s documentation that is included with the router or contact the technical support group for the router.
Shared connection with a gateway device (combined modem and router)
1. Make sure that the gateway is turned on. A gateway integrates a high-speed Internet modem with a router.
2. Verify that there is network activity by looking for the sequence of blinking lights on your gateway that generally indicate Wide Area Network (WAN), Local Area Network (LAN), and connected power status.
Note These names will vary from model to model.
3. Turn the gateway device off, and then turn it back on. This is also known as power cycling the gateway. To power cycle this device, you should follow your manufacturer’s specific instructions. Here are some general steps:
c. Reattach the power supply to the gateway by following the device manufacturer’s instructions.
d. Wait for the device to start and to establish a connection with your broadband provider.
e. Verify that the gateway shows the appropriate power and Internet connection indicator lights by following the manufacturer’s instructions.
4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Be sure that this address is correct, or set your IP settings to Automatic in the Xbox Dashboard.
5. If you are receiving an IP conflict error in the More Info section of the Xbox Dashboard, turn off all devices on the network. Try to connect to Xbox LIVE with only the modem and Xbox 360 console connected.
Shared connection with Microsoft Windows Internet Connection Sharing
1. Verify that you can surf the Internet from your PC. If you cannot surf the Internet, there is probably a problem with your Internet connection. Contact your ISP for support.
If you are using a USB modem to connect to the Internet, the modem will be listed in the "Dial-up" window as the connecter that you are sharing and that you have configured. To verify that Internet Connection Sharing configured it correctly, use the following steps:
a. Click Start, and then click Control Panel.
b. In Control Panel, double-click Network Connections.
c. Right-click your broadband connection, and then click Properties.
d. In the Properties dialog box, click the Advanced tab.
e. Click to select the Allow other users to connect through this computer’s internet connection check box.
f. Click OK.
Ethernet Properties
2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer.
3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK.
4. On the View menu, click Tiles.
5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation.
6. Enter manual settings in the Xbox 360 Dashboard for IP address, subnet mask, DNS address and gateway and test the connection: To edit the settings:
a. In the Xbox 360 dashboard, move to the System section.
c. Select Edit Settings.
d. Enter the following:
• IP Address : 192.168.0.2
• Subnet mask : 255.255.255.0
• Default Gateway : 192.168.0.1
• DNS server (Primary): 192.168.0.1
• DNS server (Secondary): 192.168.0.1Xbox 360: Test Xbox LIVE connection fails at IP address
Posted on Dec 07, 2007
Don't do nothing and buy a new one.
p5
Posted on Sep 04, 2008
2 Suggested Answers
SOURCE: xbox live not working
XBOX SHOW E68
Posted on Jun 27, 2008
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
My xbox 360 wont connect to xbox live and ive tried everthing
things you can do..... first start by connecting your 360 to the router and run a test through the system setting menu on your 360 dash board.... to do this go to system setting menu and select the network setting menu.... after selecting network setting there should be an option to test you`xbox live connection.... this is the first step in trouble shooting.... if your xbox connects to the network or router than the problem may be in the Internet connection.... after you have a connection between the xbox and the router... connect the router to the Internet and run the the test again... if you are connected to the network and the internet but still not to xbox live try doing a system update to update your system with xbox live.... after doing all of these steps you may have purchased and xbox that has been banned from xbox live and will not be able to join xbox live..... a more simple solution is that you may not have an xbox live account and simply need to set one up... this can be done through the xbox or you can go to www.xbox.com and set up a live account... you can also find FAQ's and trouble shooting steps there
Apr 22, 2010 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Can't connect to xbox live, connected to network and internet, but as soon as test goes to xbox live connection comes up with updates needed, click continue to update, the green bar goes so far after about...
Try plugging the xbox straight into the modem and not the router, if it still happens, reset your modem and router and try again. Xbox live can be sketchy at times. Also the traffic to xbox live because of the holidays can sometimes screw with the updating and such.
Dec 27, 2009 | Microsoft Xbox 360 Console
HALO 3 XBOx LIVE Cant get by PRE game lobby
Try redownloading all game-effecting things, and getting a brand new online router, get Gold, get a new 360, or reset game data.
Jun 08, 2009 | Microsoft Halo 3 for Xbox 360
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Att 2wire wireless and dlink
the only thing you need for connecting 360 to wireless is an Internet connection, an 802.11G wireless router, and a wifi adapter that connects to your 360. They have these at walmart or any gaming store. I suggest giving your 2-Wire back to ATT! NOT QUALITY. Especially for gaming.
I myself prefer my box to be hard wired as lag is far less. BUT..for wifi
Get a Linksys Router and XBox brand wifi adapter for 360. Also google xbox connect. Instead of paying for LIVE
James Mac
Aug 03, 2008 | 2wire (1000-400108-001) Router
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Xbox Live Connection Interrupted
Ok, all you have to do when it comes to buying a wireless reciever is to buy the microsoft brand one made for xbox live. (100 dollars) Once you have this;
1. turn of the xbox 360 and plug in the adapter.
2.turn on the 360 and go to the network settings option
3. this should bring up a page offering a view of you ip address and ect., go to the bottom link (3rd), and select it.
4. this should give you the option to select your wireless network, then connect to it and test the xbox live connection.
5. Once you pass the test, continue to hit "b" until you are back at the very main menu and begin playing!
Mar 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
2,539 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
