Question about HP OfficeJet 6210 All-In-One InkJet Printer
Misaligned Printing The printing on the page is off by 1/8 of an inch - meaning the printing is tilted. I have used the feature to "Align Print Cartridge" and it says the process is successful despite the fact that the printout from this process is also misaligned. The paper seems to be feeding correctly too. Any ideas on how to fix this? Thanks
  • dpriddle Dec 12, 2007
    Thanks for the advice. I just fixed the problem by cleaning the rubber wheels that pull in the paper.
  • Anonymous Jan 17, 2009
    exactly the same problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
If you do an internal test page ( there should be a button on the machine you push for this function, I'll give you the link for the manual in case you don't have it) does it come out crooked?
the alignment of cartridge is to make sure the colors are o.k. not for paper alignment.
if the internal test comes out ok then the problem is with the paper path, are the guides snug against the paper ?
if the internal test comes out crooked then the problem is with the scanner or board.
Posted on Dec 12, 2007
Lexmark p4350
Try to align the cartridges using the Lexmark software installed on your computer to fix the problem. Please follow the steps below:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark P4300 Series folder.4. Select Lexmark Solution Center.5. Select Align to fix blurry edges. Your printer will then print a page that will align your cartridges.
Try to print your document again to verify that the problem is fixed.
Dec 27, 2011 | Lexmark P4350 All-In-One InkJet Printer
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
HP C6180 won't align print cartridges
hi Alignment of ink cartridges is very essential for the for the printer to print so first of all be sure that you are using geniun ink cartridges now lets try a reset on your printer press the # and 3 button on your printer together and then unplug the power cord from your printer and keep pressing the buttons now wait for 5 sec and while pressing # and 3 replug the power cord wait for the printer to initialize and see if it prints alignment page if no page is printed then click on the start button of the computer and then go to printers and faxes and then right ckick on the icon of your printer and click on printing preferences now go to the features tab and click on the button that says align print cartridges wait for the alignment page to print and now try and see if it prints fine
Aug 26, 2009 | HP Officejet J5780 All-In-One InkJet...
PRINT IS BLURRY
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Hi! I want to align my printing cartridges on my HP Deskjet 4260 and have forgotten how. Can you help?
Hey there and welcome to FixYa:
In order to align your print cartridges, all you need to do is:
1. load some letter sized paper in the paper tray
2. open the printer software that came with your printer
3. Click FILE, then PRINT
4. next, go ahead and click PROPERTIES (sometimes labeled PREFERENCES)
5. click the FEATURES tab, and then click the PRINTER SERVICES button. This opens up the printer toolbox.
6. Click ALIGN THE PRINT CARTRIDGES
7. Click ALIGN, and then follow the onscreen instructions.
This will print a test page that aligns that printer cartridges and calibrates the printer. Easy, huh?
Here is the manual
, and if you need anything else don't hesitate to ask!
Happy Holidays,
TJ
Dec 16, 2008 | HP Deskjet D4260 Printer
Dell AIO 942 printing problem
Hi Lei,
You may try to check on the printing settings. You may need to check also if it is defaulting to all. You may try printing it by pages. If the issue persist then there is something wrong with the settings. You may also try to uninstall and reinstall the printer software if the issue persist.
Keep me posted.
Thanks,
Jeff
Oct 11, 2008 | Dell 942 All-In-One InkJet Printer
Epson Aculaser C1100 - misaligned printing
Your application will actually override the settings of the printer, what i can suggest is for you to check if you are using the correct page length and margin setting in your software program.
Try using Laserjet 3 emulation driver as well
Feb 08, 2008 | Epson Aculaser C1100 Printer
Print Problem error after 1/3 to 1/2 prints
This is not for changing carts, it's for the anti-curl function. You need to attach your printer to a computer, load the driver, try a test print from the computer, and check to see if the printer is reporting an Anti-curl motor error
Oct 14, 2007 | Alps MD 5000 Thermal Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
275 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
