Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Amp and cap wont turn on
I was playing it and it just cut off and wont turn back on again and i check all the wires and nothing is out of place.
    Sergeant:
    Champion:
  • 231 Answers
Check fuses on AMP , fuse from battery under hood , .It should not be farther than 18 inches from battery meaning the fuse..
Posted on Dec 07, 2007
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
Why car will run then once shut off wont start again, at a later date it may start again and drive S IF NOTHIng is wrong. It will just spin a couple days later it may start again. checked gas-good also...
did u inspec condition of plug wires-they wear from heat etc-take that distributer cap off n I bet inside looks like dental decay--the ignition module is equal to the points and it fails-its under the cap n can be tested at a parts place
Sep 19, 2009 | 1992 Pontiac Grand Prix
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
When i play music loud the sound cuts out
i would try getting a new amp, the speakers may be blown.
Dec 30, 2008 | Audio Players & Recorders
My Boss Amp keeps cuts off when I play the music from my stereo
check your ground wire and your remote wire, Wiggle them separately both at the amp and at the ground point. See if it cuts out then, and you;ll know which one. Also, does it have a light on it when it cuts out? if so, it could be going into protect mode, which wont allow it to turn on for a period of tine. Make sure the amp is not too small for the speakers you are pushing.
NGK
Sep 03, 2008 | Boss Car Audio & Video
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Jl audio
If the amp was hot, it probably has a serious problem. You should have it checked out by a qualified tech. Don't continue to use it. More serious damage could occur.
May 29, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Problem
Start removing wires from the amp, one by one (except for the +12V, Ground, and remote) until the amp seems to work fine. Usually, this type of issue is due to a speaker wire shorting to something it shouldn't be touching. Check the "non-amp" end of all the wiring to make sure they are solid and correct.
Apr 04, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
46 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
