Question about Nokia N70 Cellular Phone
No signal cant ring it blocked?
  • 482 Answers
Posted on Dec 18, 2007
Where is the crank shaft sensor located on a Buick century 3.1 2001
Which one ? your 3.1 l has two .7 X an 24X
The 7X (CKP) sensor is bolted into the center of the engine block and protrudes into the crankcase. The 7X CKP sensor reluctor wheel is cast into the crankshaft.
The 7X CKP sensor is a variable reluctance sensor. The magnetic field of the sensor is altered by a reluctor wheel that has seven machined slots, six of which are equally spaced 60 degrees apart. The seventh slot is spaced 10 degrees from one of the other slots. The 7X CKP sensor produces six pulses and one sync pulse for each revolution of the crankshaft. This signal must be present for the IC module to send a 3x reference signal to the PCM. The 3X reference is known as the low resolution engine speed signal.
The 24X (CKP) sensor (1), secured in a mounting bracket (3) and bolted to the front side of the engine timing chain cover (2), is partially behind the crankshaft balancer. The crankshaft balancer contains the 24x CKP sensor interrupter ring.
The 24X CKP sensor contains a hall--effect switch. A hall -- effect switch is a solid state switching device, which produces an OFF-ON pulse when a rotating element passes between the sensor tip and a magnet. This rotating element is called an interrupter ring. In this case the interrupter ring has 24 evenly spaced blades and windows. This sensor produces 24 ON-OFF signal pulses per crankshaft revolution. The 24X signal is used for enhanced smoothness and idle stability at a lower calibrated RPM. The 24X signal is known as the medium resolution engine speed signal.
Jul 11, 2016 | Buick Cars & Trucks
How do I get caller display for which I pay BT extra to work on my handsets when it works fine on the landline on my property. I have checked Blocked calls list etc but still get No Number displayed i
Do you have DSL on the same phone line? I have seen where the 58 GHZ phones sometimes are not compatible with it because of the WiFi being on the same freq. and thus stop the CID signal from coming thru. There also might be a distance issue or some type of filter on your line causing the trouble. The CID signal is sent thru between the first and second rings of the phone. So if you can get a phoneman's headset and connect it to the line to listen when the phone rings, you should hear a kinda static between the first and second rings. If not then you aren't even getting the signal to the phones.
Apr 23, 2014 | Vtech CS5111 58 GHz 1Line Cordless Phone
How to unblock calls
go to area that you block them and choose the unblock button
Jan 02, 2014 | Panasonic KX-TG9344T and 2 KX-TGA931T...
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Need puk cod i now remeber my code but i cant ring because i neeed puk code
For your puk code, you can get only from sim costumer care. And remember don't put your imagine puk code, it will block your sim card but not your phone. so call to your sim costumer care and its absolutely free.
May 19, 2010 | Cell Phones
hi ring your provider.they will give you a puk 1 code and then you should be up and running.
Sep 13, 2008 | Cell Phones
ok thats easy what u have to do is ring your carrier optus,vodaphone ect
tell them you need your puk code ,they will ask u some details then give it to u
write it down as soon as u enter ur puk it will say enter new password do that and it will say repeat then it will work good as new
Jul 04, 2008 | 11Wave amb-1101 Bluetooth Wireless Adapter
Lost samsung can i block it?
ring up your company that your with eg 02 or vodafone tell them your phone has been stolen an would like it to be block they will do it stop it an block it for u iv done it before when mine were nicked igot it blocked
May 20, 2008 | Samsung SGH-U600
Samsung E900
set all call barring and set call divert you can choose what you want!
Oct 02, 2007 | Samsung SGH-E900 Cellular Phone
Nokia N70 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
