Brothers fax MFC-8220
I was trying to find out why I get an Error 7A on a MFC-8220 fax machine from Brothers. This happens when I start the unit
  • Anonymous Jan 31, 2008
    7a error
  • Anonymous Mar 30, 2009
    machine makes horrid noise as it set up to copy fax print
  • 1,218 Answers
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Bad main motor
Posted on Jan 31, 2008
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Brother MFC 8220 Error code 71
that code indicates that your laser unit has gone bad. no way to reset or repair without a tech replacing the laser unit itself.
razors
Mar 18, 2009 | Brother MFC-8220 Fax
Brother mfc 8220 gives error message check original but no paper jam exists.
I assume you're getting this error when sending a fax?
Check original is not a paper jam error. This can happen in the winter due to bad noise on the phone lines. When you send a fax, you can get this result from the receiving machine due to noise. The receiving unit will transmit the error back to the sending unit.
The unit is basically asking you to check the quality of the original document. 90% of the time, there is no problem and the receiving unit actually got a good copy. However, sometimes due to noise on the line the receiving unit will get a poor copy of the fax. In this case the fax should be resent. Of course, since there is no way for you to determine how good the copy is at the receiving unit, in most instances you will have to resend the fax to make sure it goes though.
If, however, you are getting this message while copying (very unlikely) you can do a simple test of the document scanner that should reassure you that there is no serious fault, or pinpoint the actual fault.
Press the following key sequence within 2 seconds: MENU, *, 2, 8, 6, 4. If your unit has a FUNCTION key, use it in place of the MENU key. This should take you to maintenance mode. The display should say MAINTENANCE and all the lights should be flashing. If not, try unplugging the unit, press and hold either the MENU key or the FUNCTION key (depending on which your unit has) and plug the machine back in. This will also take you to maintenance mode.
Now, just press 5 5. This is the scanner area setting command, and if there is any problem with your scanner it will show up here as an error. If there is no fault with the scanner, the unit should return to maintenance mode in a moment. Once done, press 9 9 to exit maintemance mode.
If you are constantly having this error, get a phone repairman in to test your fax line.
Feb 06, 2009 | Brother MFC-8220 Fax
Brothers fax machine can't send out faxes
try calling brother tech support  1-908-704-1700 good luck brother tech
Jan 05, 2009 | Brother MFC-8220 Fax
Brothers MFC 8220
It sounds like your machine has a mechanical malfunction and will need to be serviced.
Aug 19, 2008 | Brother MFC-8220 Fax
MFC-8220
Its the CIS unit. Part number LE7949001. $70 retail price.
Aug 15, 2008 | Brother MFC-8220 Fax
Machine error
Laser scanner error. Replace laser unit
Aug 14, 2008 | Brother MFC-8220 Fax
826 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
