Question about GE Profile Spectra JGBP90 Gas Kitchen Range
JGBP79 Bake Ignitor not glowing, even after replacing
I have a 5 year old JGBP79WEB5WW stove and the bake stopped working, sits at 100 degrees and the glow bar does not heat up. I took it out and measured resistance, it showed 115.7 ohms. Although I didn't think it was bad since it had continuity, I ordered a replacement off the web and it arrived today. I measured resistance of the new one and it show 247 ohms. I put it in and it does not glow either.
1. Does anyone know what the resistance of a good bake ignitor should be?
2. Assuming it's not the bake ignitor, what else can I troubleshoot?
Thank you!
  • Inline Dec 12, 2007
    I'm not sure where these gas coils are. I am looking at the parts breakdown for the oven and don't see these things. Could you give me the number on the part diagram to look at?
    I have an update though. Maybe this will help someone help me fix the oven.
    I took apart the top oven control panel area to get access to the control board. I tested the relays and noticed a problem. When the oven/broiler is off, the broiler relay shows 0 VAC like it should, however the bake relay shows 6.9 VAC when it should show 0 VAC. When the bake operation is on, the bake relay shows 120 VAC like it should. So, in summary, the bake relay is showing 6.9 VAC when it should not.
    Next, I disconnected the bake ignitor and hooked my voltmeter the connector and started the bake operation. I only saw 7.9 VAC instead of the 120 VAC like it should be showing. Which explains why the bake ignitor never glows. It is getting voltage, but no where near what it should be.
    As a side note, I tested the resistance of the oven temp sensor and it read 1100 ohms at room temp like it should, so that part is fine.
    Based on what I've found, I'm assuming that the safety valve is fine, since if it failed and it's in series with the bake ignitor, I should have 0 VAC when the bake cycle is on. Therefore, I'm guessing that since the relay should incorrect voltage, that maybe something is wrong with the relay and/or the main control board?
    I'd appreciate any assistance trying to nail this down.
    Many thanks.
  • Inline Dec 17, 2007
    Ok, long story short, it seems it was the bake ignitor that was the problem. The reason for the problems with voltage is that when I pulled on the bake ignitior wiring to get to the quick release connector, it pulled one of the yellow wires off of the gas safety valve and therefore I had the voltage issues (7.9VAC). I reconnected the yellow wire to the gas valve (this stuff is easy to get to by removing the warming drawer) and installing the new bake ignitor. The oven now maintains a consistent temperture for over an hour and all looks good! Hope this helps someone else.
  • 35 Answers
My next step would be to replace the two gas coils. They are located on top the gas valve. Disconnect the elect. leads, pull upward on coils. Replace w/newones. The difference is a primary and secondary, one has two elect. prongs and one has three. Note which one goes where when you remove them and install new ones in the opposite. These tell the gas valves when to activate and allow gas to flow to your igniter. When they malfunction, and they do, you wont have gas flowing.
Posted on Dec 10, 2007
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Aug 02, 2011 | Jenn-Air Ovens
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Jul 20, 2011 | Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE Profile spectra JGBP79 oven does not turn on---gas oven
Turn off the gas supply to the range. Remove the oven racks,oven base pan,flame spreader.
Place a clamp on amp meter on one wire of the ignitor and turn the oven on to BAKE. When the ignitor glows it should read more than 3 amps. If it reads 3 amps or less replace the ignitor.
If it does not glow at all,replace the ignitor.
Jan 05, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't heat
This could be the ignitor. The ignitor is located under the bottom of your oven. you get to it from the inside of the oven. A quick check though is to set the oven to bake and wait about 30 seconds and see if you can see a faint orange glow from the bottom inside of the oven. If you do then your ignitor is probably working ok and the problem lies somewhere else.
Apr 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven doesn't work
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Oct 31, 2006 | GE Profile JGBP79 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
450 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
