Question about Insignia LCDTV26 26 in. Television
Insignia Flat Screen TV - no cable signal
I', plugging my cable chord into my new tv and the tv isn't reading any siognal.  i've tried different chords and they work with my other tv's.    Basically if it doesn't play my cable it doesn't work.  whats the deal?  anyone have this problem?
  • 1 more comment
  • Anonymous Sep 11, 2008
    i get one channel on my tv with cable when other tv's get all the channels
  • lucky519 Sep 11, 2008
    same problem
  • Anonymous Jan 10, 2009
    Same problem help!!!!!!
Hi, need some help here. I have a flat screen tv that will not go on. Its not even 2 years old. Yet I had to keep trying the wall outlet to get it to turn on. Now it won't go on at all. The tv light use to be blue when it was on. Now its pink? Should I ask santa for another, or can this be repaired without too much fuss/cost? Thanks!!!!
Posted on Dec 10, 2007
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Hdmi on insignia lcd 37 not working
just upgrade, really not worth fixing. sounds like board is bad
Aug 01, 2012 | Insignia NS-LCD37 37 in. LCD TV
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
I have an insignia ns-lcd37-07 giving to me, i replaced power supply board and i still don't get anything. what should be my next step?
Now the tv is turn on,tv have power LED light indicaton but no picture?Still have a clicking sound but no picture on the tv LCD screen panel?Yes,than the tv Tuner signal board that the other board 70% also might have the problems too.That the board where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 13, 2011 | Insignia NS-LCD37 37 in. LCD TV
I have an insignia 19 in lcd tv My tv was given to me broken. What it does is once you turn it on it will say please wait and then the screen will go black and that's it what should I fix to fix the...
The tv LED power light indication still on,have a solid color,but the LCD screen panel goes black?Yes,this problems and the causes is the tv Tuner signal board have a shorted part or parts some kind inside it circuitries and it dying.The tv Tuner signal board,that the board,where the incomming broadcasting tv signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Insignia NS-LCD19 19 in. LCD TV
We can't set up our 32 inch insignia 120Hz tv. It keeps saying "no signal." We have been on the phone to both Insignia and Comcast with each essentially blaming the other. We have a digital cable box...
Tries unplug tv and cable box replug both back about an hours.The tv now,it resetting itself back to the factory setting.The cable box is now resetting and it upgrading it softwares.The tv should work now.Not,tell the cable company sent u another box,still have same problems,the tv board call the Tuner signal board have problems,must be replace.This Tuner signal board,that the board,where the tv incomming broadcasting signal cable plug into it.If the tv is out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 24, 2010 | Insignia NS-L46X10A LCD TV
Cable won't work on new tv
When I plug in all of the cables the tv says no signal. I have tried it on all different input settings and my cable provider tried sending me a stronger signal. Could I be doing something wrong and is there anything else I can try?On the back the tv has no receptor what else is there i can use?
Aug 03, 2009 | Insignia Televison & Video
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
Insignia LCDTV26 26 in. Television Logo
443 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
