There are many reasons to flash the Phone,Once for to remove the Mobile hanging problem,Unwanted files ,reset the Phone to original settings and remove the Network Lock,But if you need to flash it from Network lock means You can better use the Unlock code,Because Flash done using the software,they leads to data lose and Hardware crash,But Unlock code is best to Unlock the phone from Network Lock,Get the code from here
Onlinegsmunlock and Unlock it..You need to specify it locked Country,network then order code and Unlock it using the Instructions below enter the code in the Phone step by step...
Nokia N72 Unlocking Instructions
Warning : Do not enter any wrong unlock
codes on your Nokia N72 mobile phones. If you enter over a certain
amount of wrong unlock codes on your Nokia N72 mobile phone, your phone
may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N72
without any sim card.
2 - Don't bother as to what is displayed on your Nokia N72.
3 - Compose
#pw+CODE+1#.
4 - The Nokia N72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose
#pw+CODE+7#.
The letter
p appears if you press the button star(*) three times quickly
The letter
w appears if you press the button star(*) four times quickly
The symbol
+ appears if you press the button star(*) two times quickly
The
CODE you need to enter is the unique unlock code for your Nokia N72
