Question about Microsoft Xbox 360 Console
Hook up to t.v.
How to hook up to the t.v. the t.v. connector is throwing me.
    President:
  • 4,402 Answers
Audio Video cables to your XBOX and TV, make sure the ones going to the TV go into 'Audio in' and 'Video in'.........plug in the power adaptor and plug the other end in the XBOX, start the game system and make sure there's a game in there, now just find the channel your game settings are on (usually 3 for some people, or TV/VIDEO for the rest), and oh yeah don't forget to turn the TV on..
Posted on Dec 08, 2007
Check engine light comes on and dealership can't find out why
There's a "Diagnostic Link Connector" (DLC) under your driver's side. One needs a "scan tool," your "dealership" should have one. Hook-up the scan tool to the DLC. Read the DTCs, i.e., "Diagnostic Trouble Codes." Then repair the problem.
Nov 05, 2016 | Cars & Trucks
How do you uncouple the cooling fan wiring when removing fan mounting to replace a fan?it is being difficult
Automotive electrical connectors typically have a latch to prevent accidental disconnection. Wipe off the connector thoroughly with a rag, and make sure you have a good light available. Examine the connector carefully for tabs that go over hooks - typically they are on the longer sides of the connector. Sometimes the latches require squeezing a lever actuator to pivot the tab away from the hook, but usually you must pull or pry the tab directly off of the hook. Be very careful not to pull too much - just enough to free the hook so you can pull the connector shells apart. You don't want to break the latch.
Aug 03, 2015 | Cars & Trucks
How do i remove the latch system with my car seat?
Remove the connectors from the automobile?
If the connectors are hooks, I suggest you first loosen the latch strap (depending on the seat, you may need to push a grey button to release the strap). Then, squeeze the hook and push the connector into the seat bight, Rotate the connector 90 degrees (along the length of the connector) and pull the hook out.
If you cannot remove the connector, go to www.nhtsa.gov and look for a fitting station in your area. They will help you.
-- Marc
Passionate Child Passenger Safety Instructor
Aug 14, 2014 | Safety 1st Alpha Omega Elite 3in1...
Dodge Ram 3500 Diesal 2004 keeps throwing code
contact your dealer service department with the code and they should have no problem hooking you up with the problem
Dec 29, 2009 | 2004 Dodge Ram 3500 Truck
Check engine soon light on ,throwing code p0174 running lean on bank 2, on a f150 pickup. what would cause this?
Engine size???? The most common cause for that code is a PCV line leaking vac. Check the PCV line form the right valve cover, to the back of the intake manifold. Where the line hooks to the manifold is a rubber connector, and thats where they leak. Note the number thats on the line, the dealer will need that as there are 20 different PCV lines. If the line is ok, you have different problems and a repair shop will need to ck it for you.
Dec 18, 2009 | 2001 Ford F150 Styleside SuperCrew
How do I hook up the dvd/vcr to the tv and the converter box
The antenna is connected to the converter box then connect the box to the vcr on channel 03 throw the rf connector now connec the vcr to the tv set and use the converter box to move the channels you want to see good luck
Jul 02, 2009 | Philips Magnavox DVD/VCR Dual Player
2000 montana brakes shutter and the abs light and
i had the same problem on my 2000 montana, used a scanner to check for abs code and found right front sensor throwing code, checked sensor and found ok, checked harness from sensor to connection under hood and found wiring circut at the plastic clip where harness hooks to sensor was bad, replaced harness from connector to sensor and problem went away
Apr 20, 2009 | 2000 Pontiac Montana
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
Microsoft Xbox 360 Console Logo
62 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
