Question about Sapphire RADEON 7000, AGP Graphic Card
AGP texture acceleration not avalable :(
Hi
I have assembled an hold Pentium 3 at 1.0 ghz on a mobo soltek 65kv2 ct 512 mb sdram 133 and a Sapphire radeon 7000 64 MB DDR, the problem is that i can't enable the agp texture acceleration on dxdiag i tried everything win me win 2000 and xp nothing works :( i used all updated drivers video and mobo could you help me please
    President:
  • 2,351 Answers
Well your card is still an ATI & things have changed a bit. You don't just need the drivers but you need ATI's Catalyst Control Center. Through the Catalyst Control Center you have a ton of control that you just don't get with drivers alone. Suggest you update windows first. You'll need .Net framework 2.0 min. Do not skip lower versions of .Net framework & only install one at a time. Install DirectX 9.0c from Microsoft here: http://www.microsoft.com/downloads/Browse.aspx?displaylang=en&categoryid=2
Than download ATI's Catalyst Software Suite File size 46.6MB:
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
Uninstall any other versions currently installed on your system.
If for what ever reason the uninstall fails download and run ATI's uninstaller "cat-uninstaller.exe" to clean your system from here:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Don't forget to vote!
Posted on Jan 08, 2008
Err i know this is an old post, butif by chance your card is a PCI card, it won't have agp texture acceleration. or at least that's the only thing that comes to my mind o.o just thought i'd share.
--PtK
Posted on Jan 18, 2009
What kind of memory does an HPPP2090 has? Does it have capabilities to add more memory and how fast does it run?
Hi - The machine uses SO-DIMM 200 pin DDR SDRAM @ 333 MHz also called PC2700. It came standard with 512 Mb and can be upgraded to two GB. It has two ram slots.
The Laptop was available with Intel Pentium M CPU's at 1.6, 1.7, 1.8 and 2.0 GHz.
Regards and thanks for using Fix Ya
Mikeywaf
Mar 18, 2011 | HP Computers & Internet
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
    If new processor supports your old motherboard then you will upgrade system with your old motherboard.
    If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
    Thanks.
    Happy to help you.
    Apr 30, 2010 | Intel CPU
    Graphic card for GA-8IPE1000 series
    HI there.
    There are loads of makers of memory and graphics cards out there to choose from.
    For the ram i would recommend Corsair or Kingston, you can get this ram as a matching pair so the both run at the same speed, the best ram to get is DDR 400.
    As for the graphics card, i recommend ATI radeon X1650 Pro 512MB graphics card.
    These upgrades will make your machine purr like a kitten with an excellent gaming experience.
    Good luck and thanks for choosing FixYa!!
    May 27, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
    RAM cuantity
    The motherboard you mentioned supports DDR1 RAM.
    For windows xp and general application 512 MB is enough.
    But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
    Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    That is because your system does not meet the minimum requirements to enable it. Your prblem is with the graphics adapter agp - Axcellerated Graphics Port, YOu will need to have a compatable Graphics Card to do it along with a processor at least 1.66 ghz
    Jul 20, 2008 | Intel D845GVSR Motherboard
    Mainboard SL-65KV2-CT
    yes i told you that but i change my mind
    throw your computer upside down
    and after that buy my computer
    Pentium 1 75 mghz
    24 mb ram
    640 mb hdd
    1mb vga
    May 09, 2008 | Soltek SL-65KV2-T Motherboard
    UPGRADE
    U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
    Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
    Hi all, I am running Gigabyte M59SLI-S5 mobo, 6000x2 CPU, 4gigs 1066ram, 2 dvd-burners, a 6600GT vid card, and an X-fi sound card, all powered by a 650watt BFG PSU, in Vista Home Premium. Ever since I installed the new ram my pc is running very unstable, It isn't the ram as I've run various mem testers and what not. Every time I tell my PC to shut down it doesn't, not all the way. My monitor turns black, vid card and HDD turn off, but the RAM is still running (can tell because of the LED's on it), and so is the PSU (lights are on). What could cause this? I also don't have any viruses. I had problems with my old ram in this same mobo as well.
    Also another problem is that sometimes when I boot my pc it has mobo Bios F4, and sometimes it shows an F8H. So it doesn't always boot under the same revision of the BIOS. I've tried flashing the BIOS and reupdating, but each time I do that it stays at the f8h version a few days then sporadically reboots in F4 or F8 revision.
    What do I need to do? Get a new mobo? And is it unsafe for parts of my pc to turn off but the psu and ram not to? I wanted to wait until March or so to get a new mobo, but if this will damage other components should I get a new one now? I appreciate all answers, as I am completely bewildered by this, and no one I know has ever heard of this.
    And a side note, I have checked my running temps and my CPU is about 40C under load and whole system case is about 27C under load.
    Dec 06, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
    Sapphire RADEON 7000, AGP Graphic Card Logo
    524 people viewed this question
    Top Sapphire Computers & Internet Experts
    Rajendra Singh
    Rajendra Singh
    Brett Duxbury
    Brett Duxbury
    Bill Boyd
    Are you a Sapphire Computer and Internet Expert? Answer questions, earn points and help others
