Question about Toshiba TP50H50 50" Rear Projection Television
Toshiba hometheater 50" rearprojection
Tv no sound or picture blinking red light. Used to reset by unplugging, not any more.Also remote wont shut tv off.
  • 3 more comments
  • Jerry Midler
    Jerry Midler Apr 06, 2008
    I have a Toshiba TP50H15. The problem started with the convergence changing, then it would pop back. It progressed to a flashing power light, but I could reset by unplugging and replugging. This worked fine until we went to Arizona for 3 months. Upon returning, it wouldn't power up, but would flash the power light. I did get the menu to come up a few times before the light flashed, so I know that function is there. I suspected a voltage problem due to dust etc, so I brushed and vacuumed everything, then replugged connectors. Now, the channel will appear, but the background screen is red, so I may cave contributed to the probnlem. A service manual would sure be a help. I have seen comments that this is probably a convergence IC. Also saw a link for replacements for about 9 bucks. Do you concur that this may be the problem? If so, which one is for the red? Thanks. I like this set and the Home Theater sound and sure would hate to junk it if repairable.
    "Found replacements att Electronics Parts Center oonly $8.94 each."
  • guarionex_gu Nov 16, 2008
    my tv is shot down and the red light is blinking
  • cory_yates Jan 14, 2009
    The power clicks on and red power light flashes but no sound or picture used to unplug for a while and would start working again also noticed a lot of red tint in the picture
  • Jerry Midler
    Jerry Midler May 11, 2010
    BTW, I found a Sony Service Bulletin that listed STK392-110 (old number) and STK392-150 as the new number. Does this apply to the Toshiba replacement as well? Both appear to be available, but the new number is a bit cheaper. Are they interchangable? Did they just increase the voltage rating?
  • Anonymous Mar 23, 2014
    No picture lamp light blinks
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Posted on Mar 11, 2008
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Toshiba 50H71 projection tv
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Toshiba TP50H50 50" Rear Projection Television Logo
415 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
