Question about Dell INSPIRON 1300 Celeron 1.4GHZ,256MB DDR,CDRW/DVD,WIFI,40GB,15" WIDE LCD,WINDOWS XP (617977104046) PC Notebook
Unmountable_boot_volume technical info:stop: 0x000000ED {0x823cf030,0xc000009c,0x00000000,0x00000000}
    Novelist:
  • 69 Answers
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to error messages . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Well, this issue could causes due to below :
1. Hard Disk Drive Failure.
2. Operating System Error.
3. Could also happen if the connecting cable between Hard-Disk Drive to Motherboard on PC is bad.
To isolate and to resolve the issue, please try below solutions....
Solution 1:
First, try to enter to BIOS while you restart your PC. You can enter in to BIOS by pressing a key that says like "Enter Setup ", press F2 or F5 or F8 while booting of PC.
Note, the key to enter to BIOS is unique for PC, hence please refer to Screen that says at start up, you should see few keys that are available for entering in to SETUP.
once if you are able to enter in to BIOS successfully, then please try to locate to options that says like Hard-Drive test,, this is generally located under tools or under Diagonistics
If test is fine, then drive is okay, else if it resports a message with word "Failed " at the end/. Then it confirms that Hard Drive Is fault.
Then please replace a new Hard Drive for PC.
Solution 2:
  1. Insert the recovery CD and restart the computer.
  2. Just after the keyboard lights flash on and off, press the Esc key.
  3. Select CD-ROM , then press Enter .
  4. At the message Press any key to boot from CD , press the spacebar .
  5. Press R to enter the Recovery Console when shown.
  6. At the message Which Windows installation would you like to log onto? press 1 , then press Enter .
  7. Type in the administrator password when prompted. If no administrator account has been set, leave the password blank and press Enter .
  8. At the C prompt, type chkdsk /r , then press Enter . The Chkdsk program checks the hard drive for errors and repairs any error it finds. Chkdsk takes at least twenty minutes, an hour or more is also possible.
  9. After the Chkdsk program is finished, type exit , then press Enter to restart the computer.
After the computer is working, install all critical updates for Windows to prevent this error from occurring again
for more information please go through below information :
http://support.microsoft.com/kb/297185
This should resolve the issue for you.
If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Dec 06, 2007
  • 56 Answers
This happpens when either you have a damaged file system or are using a 40 pin calbe when a 80 pin is req. To fix a damaged file system restart into the recovery console and then use the chkdsk /r command to repair the volume. After you repair the volume, check your hardware to isolate the cause of the file system damage.
Unmountable boot
Hi
You will need to get the original windows disk you was sent.
Put it in the laptop and run the 'RECOVERY CONSOLE'
this should bring up a command line, (command prompt)
Type :
1. fixboot
2. chkdsk /r /f
If they both fail you will either have to put your hard drive on a cradle and write another boot directory to it, or you will have to reformat it.
Mar 30, 2013 | Dell LATITUDE Computers & Internet
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
This what my laptop says, it says ***stop: 0x000000ed (0x812ace30, 0xc0000006, 0x00000000, 0x00000000) that is the technical information on the blue screen unmountable boot volume and i dont...
To repair follow these steps:
  1. Start your computer by inserting the Windows installation disk if your computer can start from the CD/DVD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
Jan 20, 2011 | Computers & Internet
Stop: 0x00000ED
0x000000ED Unmountable Boot Volume
Boot to the Windows CD, go to recovery console, run CHKDSK /R see if the issue resolves, if not replace the HDD
May 15, 2010 | Dell Dimension 2400 PC Desktop
Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
and then replace this will reconfigure your
motherboard and hopefully solve your problem.
Feb 15, 2010 | Dell Dimension 2400 PC Desktop
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Dell INSPIRON 1300 Celeron 1.4GHZ,256MB DDR,CDRW/DVD,WIFI,40GB,15" WIDE LCD,WINDOWS XP (617977104046) PC Notebook Logo
326 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
