Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai PT5598 rear projector TV
My tv, which has always worked great, suddenly lost its picture (as if the tv had been turned off). We have sound, can change channels with the remote, but simply don't have a picture. Any suggestions on what may be the problem?
  • 1 more comment
  • UNLCE TOKPAH Mar 21, 2008
    MY AKAI PT5598HD 55 IN REAR PROJECTION HDTV READY HAS NO PICTURE. HAS SOUND.THE LITTLE RED LIGHT ON THE POWER BUTTON FLASHES A FEW TIMES AND GO OFF
  • Anonymous Jun 25, 2008
    Same problem--At just over two years old, my Akai PT5598HDIX suddenly lost the picture, but the sound is still functional. Customer service stepped me through the reset procedure (unplug for ten minutes then try it again). That didn't work so she told me to connect a DVD play to see if the television could display that image. No such luck. Next move was to try to order the service manual, but the web page warned that it wouldn't ship right away. I canceled the order pending a reply from customer service on how long they think it will take.
    JG
  • jbhughes2003 Jul 18, 2008
    My PT5598HDIX picture went out. A couple of wavy thin lines appeared for about 2 seconds and then lost the picture. I get the normal sound when I change channels still, but get no picture either through cable or antena. I unpluged it for overnight but that did nothing. I tried the menu and even the picture perfect but recieve no visual at all. I would like to repair it myself if I knew what it was. I feel it might be expensive to fix. Any help would be greatly appreaciated. Thanks,
    JIM
Thanks for the response, Willtab. There are no unusual noises at all. I spoke with someone else with the same problem, and he determined that he had a bad zener diode on the power supply board which also took out a electrolytic capacitor in parallel with it, but replacing it didn't help and the new zener soon went bad. I checked the same components on my unit and no voltage on the 5.1V zerer. I'm guessing that if someone finds the root of this problem we will all be able to get our sets working again. It sure would be nice if Samsung would help.
JerryG2K
Posted on Jul 25, 2008
    Genius:
  • 1,030 Answers
Usally when this occurs your looking at high voltage problem. flyback, horizontal, crt issues, do you hear any high voltage static or cracling when you turn it on or off
Posted on Mar 18, 2008
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
Nov 05, 2009 | Toshiba 26LV610U LCD TV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Sudden death
Take out ur antena,cable ect.. input have any noise.Or tv could have dead video.
Aug 16, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Have lost sound on several od our channels
Thank you for your concern. Yes the problem is solved. It turns out the cable company did something to change the settings on our audio. Don't ask me what or how they did it but someone told us about it and how to correct it
Again thank you very much
Dec 11, 2008 | Sharp 19 in. LCD HDTV
Sony /tv /no picture but sound
There is a fault on the line output stage either dry solder joints on then transformer or relating components or the line output transformer or transistor is faulty and needs replacing. Hope this helps.
Jul 17, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Plasma-No picture
Main logic board $124 fixed mine email me rudog3369@yahoo.com!!!
Apr 26, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
362 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
