Question about Sansui VRDVD5000 DVD Recorder/VCR
Sansui vrdvd5000 dvd recorder/vcr combo
When hooked up to t.v., it will play dvd, but only sound on vcr/no picture
SOURCE: sansui vrdvd5000- need manual
I have mine hooked up with a standard video/audio RCA cable.
Just plug the yellow video cable into the video output (yellow) in back of the Sansui and into the video input of your TV. Same for the audio cables (red and black usually).
Record a VHS to DVD:
Put a blank DVD-R in DVD
choose YES when it asks to format disc.
switch to VHS
Put tape to copy into VCR
On the remote press <play> then <dubbing>
If you want to play in any DVD player:
*After* recording VHS to DVD:
1) Put DVD back into unit.
2 ) Press "DVD" on remote.
3 ) DVD light will light up on the unit: press "set up ">>>"system set up"- press enter>>> "disc set up" press enter>>>"finalize" press enter >>>>choose "yes" and wait until disc finalizes.
If finalize bar stays on for a long time and isn't moving, press stop or eject DVD and wait a while. Wait until their is no movement in the bar for a long time. DVD Should now be finished and usable in any DVD player.
Posted on Aug 02, 2008
  • 155 Answers
SOURCE: Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
either the lens is weak in your dvd player or the get your cd checked in another dvd player to confirm the doubt.what exactly has problem.the player or the disk. thanks.
Posted on Oct 26, 2008
  • 224 Answers
SOURCE: setting up timer record
see if you find your manual here
Posted on May 01, 2009
SOURCE: Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Posted on May 11, 2009
  • 5568 Answers
Your model is a DVD player only and has no recording capability. There are devices that will allow you to transfer your VHS tapes to a computer equipped with a CD/DVD writer to preserve them on disk.
Tevion is one make that comes to mind.
Posted on Feb 15, 2010
  • 1285 Answers
SOURCE: My DVD recorder will not recognize any of the DVDs
yes, that is the solution... try to get the DVD that is 4x (Maxell, Dynex) most are all up to 16x now... unless you can find a firmware update for Sansui (I tried already for you, but you can with out a doubt try too)
Posted on Nov 20, 2010
0 characters
1 Points
Lost remote, need activation code for universal remote
If only you could tell us what brand of universal remeote you plan on using, maybe we could suggest some codes
Mar 08, 2013 | Sansui VRDVD5000 DVD Recorder/VCR
I lost my instruction book on Sansui vcr/dvd recorder. Help!!
I believe the VRDVD4005 manual (which is the same as the VRDVD5000) is available on a Sears sponsered website called I hope this helps you.
Jan 09, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
May 15, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Burning home movies from recorder to disc
make sure its finalizing the disc you may have to go into menu or options to check, but if plays in the but not in standalone thats sounds like the problem.
Feb 13, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sansui vrdvd5000 no manual no remote anyone know how to record vhs to dvd
I believe the VRDVD4005 manual (which is the same as the VRDVD5000) is available on a Sears sponsered website called I hope this helps you. The customer service number should be on the back of the unit to order a remote.
Jan 31, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
What type of dvd do you need to use to record?
If you click on the "VRDVD5000 DVD Recorder...Combo" link at the top of the page and scroll down towards the bottom of the page that brings up, you'll find an outline spec for the machine. Just looking at that, it would appear you ought to be trying "dvd-r" - (The difference between plus and minus is significant - it's a shame nobody thought to make the names more distinctive). Suggest you buy a single dvd-r, see how you get on, and only invest in a bigger pack once you know it's going to work. A.
Apr 17, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui VRDVD5000 DVD Recorder/VCR Logo
Top Sansui DVD & Blu-Ray Players Experts
Josh Whitehead
Josh Whitehead
Are you a Sansui DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
