Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Please Help!! I'm having color issues with my Panasonic PT-53WX54. I was told it was convergence. Is there a box or chip that can be replaced in order to fix this problem or is my tv screwed?
  • xxxpunkchick Dec 06, 2007
    How hard is it to fix myself and is it expensive to replace. I have read several reviews regarding this television and it looks as if I could do it, but need a little professional advice. Thanks bunches ;)
  • 1,153 Answers
Convergence amp, but you will need to replace return resistors also. And maybe fuses in the same area.
Posted on Dec 06, 2007
Picture looks 3d colors not lining up
The tv have a problems known as a convergence picture problems.That why ur tv colors lines R,G,B are mis alignments,have colors shadow pictures or have 3D pictures look alike?The tv convergence board it is dead.Tv Convergence board must have it parts like 2 STK convergence ICS and some or all of resistors to be replace too.To fixed the tv convergence board to solved tv picture convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 09, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Dec 30, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic pt-53wx54 53in
There are three screens on your set.
The front one is called the SCREEN PROTECTOR.
The second one has lines in, and it is the LINTICULAR SCREEN.
The third one is the innermost one and it is the FRESNAL SCREEN.
i usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of screens that are available.
The outer one that is shiny is in stock at Andrews and it looks like it would cost around $120.00 plus shipping. I have ordered these in the past and if the box looks even a bit damaged, DO NOT ACCEPT IT.
they can break very easily. The part number that is for the clear outside one is TKG2AD00131.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Mar 14, 2010 | Panasonic PT-53WX54 53" Rear Projection...
The blue color is arching along with the yellow and i cant converge them enough someone told me about having the color CHIPS or what ever they are called replaced. I would need to know whta the part...
You can get the PT53WX53 convergence repair kit from which is the correct one for your model. The Kit contains the Convergence ICs the six resistors and the Cd with instructions.
Jan 14, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Picture Stretch on Panasonic PT-53WX54
Usually this is an indication of a failing capacitor in the vertical circuit. Have those been checked? I would look for 100ufd caps in the vertical circuit. Check with the tech.
Jun 02, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Comvergence Problem
Panasonic part #C5AA00000203.  Type #STK392-110.  You can also use stk392-120 or STK394-160.  I recommend you replace both IC's as the one that is not now bad will likely fail shortly.
Oct 14, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54
you have defective convergence amps and should be replaced by qualified tech....john
Sep 10, 2007 | Panasonic PT-53WX54 53" Rear Projection...
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
