Question about McCall 4-4045 Commercial Refrigerator
Where can I find parts for McCall frezers in the US?
Need a fan motor and a fan guard (or shield) for the 4-4045 UFC
  • Anonymous Apr 30, 2008
    I may need parts for Mccall 4-4045R A gradual rise to 50 degrees (outside digital), I had a freon leak repaired last year, the compressor appears to be functioning. The unit is a 1996 model. Any ideas? An inside thermostat states 40 degrees. The dial is turned to the lowest setting. Thankyou Debbie Dobritch
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
Evaporator fan motor kit Gasket/door f.F. Gasket - door frezer
Need these call Bi Coastal Appliance Parts
Nov 03, 2010 | Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Fridg is not cooling.frezer working real good.
Open the freezer compartment and listen for the fan motor if you don't hear it but you can hear the compressor running. youll need to first make sure that the door switch is working( If the lights go off when you press the button it should be okay). You'll need to remove the back panel and inspect the coils if frosted over evenly and the fan still is not working give the fan a little push. if it will not go, you need to see if it has voltage if so, replace the fan. If no check the defrost terminator which only on amanas will keep the fan off. In this case replace the defrost terminator(it look about like 5 quarters, with 2 wires clipped through the evaprator coils in back of freezer.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
Fan and fan guard needed for 3 hp motor. Have serial number for motor on a 12 inch craftsman tablesaw.
I'm assuming your saw is a model 351.228040 or a 351.228020. Manual is here.
See page 18, Figure 7 for the Blade drive exploded diagram.
Sears doesn't appear to have a part number for the fan and fan guard.
It looks like you can replace the entire motor and key for $217.55 (as of 6/13/2010) which isn't too bad for a 3 HP motor. Part number is 15094.00 and clicking it will link you to their parts site.
If this answer was useful, please give it a thumbs up. Thanks!
Jun 07, 2010 | Craftsman 10" Table Saw
The fridge is not working and the frezer has a low temperature
be carefull when you remove the panel inside the frezer it may be you have a build up of ice and the panel could get frozen to the ice, best idea is to turn off the fridge/frezer for 24hrs to let it thaw
Oct 15, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Frezer temp is 20 deg. fridge temp is 47 deg.
Remove the freezer shelves and bins. Remove the freezer back panel to access the fan motor.
May 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Need to replace front wheel dust guards/shields.
check ebay first.
used car-part.com
new tascafordparts.com
May 20, 2009 | 2003 Ford E150
My McCall refridgerator's fan is not turning
there is a possibility that the motor has failed due to long term moisture exposure
Sep 18, 2008 | McCall 4-4045 Commercial Refrigerator
McCall 4-4045 Commercial Refrigerator Logo
163 people viewed this question
Top McCall Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
