Question about Maxtor Hard Drive
Bios not recognizing my new hard drive, have new hard drive cable also.
I have a IBM based desktop computer and have installed many hard drives on this computer, but this time the bios is still says Primary Master not installed, I checked all the cables and tried jumper on cable select! Is there something wrong with my motherboard?
  • 4 more comments
  • GeorgieQ Dec 07, 2007
    I got the bios to recognize the hard drive now, but it's a 160 GB hard drive but bios only recognizes 137.GB of it! what can I do to make it recognize the whole 160 GB.
    How can I upgrade the Bios, I don't have it hooked up to the internet yet? I'm installing Windows 2000 in it right now, it's almost done formatting. It's a new hard drive.
    Ohhhhh!! I see! so what info do I need about the bios in order to upgrade it? I'm obviously new at upgrading the bios! and what will upgrading the bios do for my computer?
  • GeorgieQ Dec 08, 2007
    Oh! It's an Ami (that's the brand right?) oh! okay! I check it out! Cool! can I still do that even after I have Windows installed?
    And that will make it recognize the whole 160 GB right?
  • GeorgieQ Dec 10, 2007
    I didn't do the Bios update yet, but I found the bios info on my computer that I need and I'll check out that website. You've been a great help!!! I REALLY appreciate everything you helped me with already!
    Merry Christmas!,
  • srkiiq Jan 01, 2008
    i have a WD Caviar SE WD2500AAJS drive model. I try to use it in my PC, but i can,t see it in a BIOS setup. My motherboard is MSI K8T Neo MS-6702 Ver:1.0, chipset VIA VT8237 with two SATA connectors. I try everithing, but no result. I also use a two same ATA WD Caviar 80 GB. My problem is only WD Caviar SE WD2500AAJS.I will be very grateful if you can help me about this. I'm from Serbia and my english is not very god.
  • 317 Answers
1) Try upgrading the BIOS software (flash it) according to your BIOS manufacturer.
2) What OS are you using?
3) When you fully format a Hard Drive (of any size) part of it is lost to the formatting process, have you checked if you have another partition on that hard drive?
- CoolDragon )O(
Posted on Dec 07, 2007
  • 2 more comments
  • Baja Data / Jay Arias-Chavez
    You don't need to have THAT computer on the internet, just write or type down what make and model the BIOS is, then visit the website from another PC connected to the internet; and download whatever is necessary and either burn on a CD or copy to a diskette.
    Hope That Helps!
    - CoolDragon )O(
    Ok, enter the BIOS setting (depending on what brand it is, it could be DEL or F2 to enter upon startup).
    Look through the menus to see what version and brand it is. Usually it's AMI, Award or Phoenix.
    Then go to the respective website and look for an update to that BIOS.
    - CoolDragon )O(
    I cannot guaratee that, but a BIOS update can help a lot!
    Further support for AMI BIOS is here:
    If you need further help, contact us at FixYa.
    - CoolDragon.
    Was your problem solved? Do you have more information or questions?
    If not please let us know, please rate the solution.
IBM thinkcenter says no os after installing DVD writer
Did you install a SATA or an PATA (IDE) drive?
First check that the data cables are connected to both the hard drive and the motherboard. (I know that I've frequently had the cables come loose from the motherboard on my ThinkCentre 8433 when I work in the case.) Also check that the power cables are firmly connected.
Next make sure that you have no disc in the DVD writer. (Or enter the BIOS by pressing F1 (IIRC) repeatedly on start up. Make sure that the hard drive is the boot disc.) While in the BIOS, you can check if the hard drive is recognized by the motherboard. If you don't see the disc listed, recheck the data and power cables.
If the hard drive was working before you replaced the dvd drive, you may have changed the master/slave assignment on the drives (if they are both IDE). Remove the drives from the computer and check the jumpers. (These will depend on the manufacturer. Use either cable select or master/slave as needed) The boot drive should have the jumper set to master or cable select. In the case of cable select, the boot hard drive should be connected to the black connector. The slave drive goes to the grey connector.
If you connected a SATA drive, try swapping the SATA ports (SATA 0 or SATA1) that has the optical drive connected to it.
The next thing to try requires either the Windows install or upgrade disc for your version of the OS (including the Service Pack) or a third party partition manager/repair utility disc. You'll need to reset the boot order to boot from the optical drive (or press F12 on starting the computer). Use the Recovery Console (for the Windows disc) to find any existing OS installs on your hard drive and attempt to repair the master boot record or boot sector if it still exists on the drive. Please add a comment with your OS for specifics on using the Recovery Console. (I replaced my WinXP with Win7 and the methods are different.)
You may have been unlucky and had the hard drive fail while you were working in the computer. See if the recovery partition (F10 on boot) still works or use your system image (Rescue and Recovery DVDs) will restore your computer to the last backup. Try doing the restore to a new hard drive if the recovery discs don't work.
I hope this helps. Please add a comment with any comments that will help me give more specific assistance for your missing OS.
Aug 09, 2012 | IBM Computers & Internet
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
How do you install another hardrive
Just remove the case, change the new hard drive to slave using the jumper setting (which is Physical), then check in your bios if the hard drive is detected.
Apr 04, 2010 | Gateway GT5692 Desktop Computer
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Dell 340 will not recognize my cd or dvd drive.
check if you see any light on the drive, if yes. then the power is there and then the problem is with the data cable of the cd drive. try to repalce the cd drive with another cd drive. if it still doesnot work and if the same cables work with the hard drive, then the cd drive has gone bad. and if the new drive also doesnot work then reinstalling the operating system should fix the problem only and only if it appears in the bios. if it doesnot appear in the bios. then the problem is not of the operating system. then its the motherboard.
Oct 13, 2009 | Dell Precision 340 PC Desktop
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Sep 07, 2009 | IBM ThinkPad 570E Notebook
2nd Hard drive not recognized
If your using IDE hard drives i would try to put them both on the same cable on the primary IDE controller. Then set you main hard drives jumpers and the second hard drive to cable select not slave. Try to boot if the boot fails your goiong to need a Windows 98 boot floppy with FDISK. You need to start up the 98 boot disk with out CD support then when it reaches a command prompt start fdisk. ONce fdisk is up format and partition the second drive. Now it should work. :) Check that the harddrive is detected in the BIOS, it may have become disconnected, it should also be the master drive on the primary IDE. If the drive is not detected in BIOS there is little chance of it working
Thank you....
Jan 29, 2009 | IBM ThinkPad X31 2672 Notebook
Hard drive problem
I've been wrestling with tw IBM's with similar issues for the last three days, one of which wouldn't recognize the hard drive or the CD drive. I'm going to suggest flashing the bios, this worked on the ones I have. Here's a link to the bios download. I recommend that you use the one for creating a diskette. Try this and let me know.
Sep 05, 2008 | IBM ThinkPad R50e Notebook
I just installed a new hard drive on my desktop pc. This is a second hard drive because my current one is getting full. I followed directions jumpering the new drive as the slave but my computer is not...
Most computers use the cable select setting to jumper the drive. Try that setting and see if the new drive is seen in BIOS.
Once seen in BIOS, then boot to XP and initialize the drive in Disk management.
May 16, 2008 | Computers & Internet
Maxtor Hard Drive Logo
244 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
