Hi when just turned on my lg split system is blowing out some particles that look like dirt or fluf. Its getting annoying as it covers a lounge with it and i cant undrestand why is doing it as the regular cleaning is done
This dirt or fluff is coming out of the blower area of the furnace. If you have a filter in the proper area then the debris you are describing may be from the insulation around the fan where it is located in the furnace. If these bits of debris has the apperance of black fluff then that is whats going on the insulation aroung the fan inside has come loose and is being picked up by the fan blowing it into your house. The way to repair this is to access the fan area of the furnace and remove the loose insulation. Remember to disconnect power to the furnace to ensure system does not turn on while you are removing the debris. Also remember that there will still be some debris coming out of the system for a while once you have corrected the problem due to the debris being in your duct work from the previous problem however it will slowly disapate.
Good Luck on your repairs
Dave
Was this helpful?
Yes
No
Popular Solutions for LG LSC121PMA Split System Air
split unit. when i put aircon on , compressor comes on 4 a few seconds and then it goes off,...
(More)
split unit. when i put aircon on , compressor comes on 4 a few seconds and then it goes off, relecting a F6 error. tryed plugging it completly off, bt F6 error appears. goldair unit
when 1 air con is switch on ,the outdoor unit produce a normal noise,but when 2 or more air con is...
(More)
when 1 air con is switch on ,the outdoor unit produce a normal noise,but when 2 or more air con is switch on,the outdoor unit produce a veri loud noise.
When we turn on the split system the two green lights come on and in a few moments the left one goes...
(More)
When we turn on the split system the two green lights come on and in a few moments the left one goes off and it should start and it's not??
I lost my air con remote and want to know if the air con has a power button on it? I have a Totaline...
(More)
I lost my air con remote and want to know if the air con has a power button on it? I have a Totaline split sytem unit.
