Sony PlayStation® 3 (60 GB) Console Logo
Posted on Sep 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ps3 just stopped playing video discs and blu ray discs today. help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
173
Points
My ps3 has stopped playing some games(lego batman and lego starwars) and wont play others (modernwarfare2 assasin creed2)at all but is fine with some (bfbc). Its my first go at modern and assasin they are both brand new fresh out the boxes please help
Anonymous
Level 3:
President:
  • Master 1,382 Answers
  • Posted on Sep 01, 2009
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
552329
Points
5097
Goto settings at the main menu of the ps3, go to the left to settings, then go down to BD/dvd settings go down to BD 1080p 24hz output and disable it.If this doesnt work out for you call up Sony, theyll get you set up with the repair process. before you call them though, be sure to restore system to default settings, because they will ask if youve done that yet.Their number is 800-345-7669 (800-345-SONY)
Sometimes if you get a blu ray disc outside of your region, then it's not supposed to work. If you live in the US, then only Blu Ray movies from the US will work.
4helpful
2answers
I have had my ps3 80gb for a couple of years now but have never tried to play a blueray disc untill today. An on screen message states that I must renew the encryption key. Perform a system software update...
You will not be able to play some newer disc because of the technology embedded in them. The updates allow for those necessary files to be implemented into your system giving it the ability to play games and blu rays. Get your system updated.
Download the firmware from the playstation official website onto a usb
stick. Follow the instructions on the website at: www.playstation.com (the update will be at the bottom of the page, on the right side.)
1helpful
2answers
PS3 BLU-RAY DVD PLAYER REGION FREE
This is because you bought the ps3 from america, it will not let you play anything you buy from europe, i had this problem when i was in germany too i had bought the ps3 in michigan and tried to play in germany and got the same exact error code. i just ordered all my games from amazon. but eventually bought a new ps3 from their region. i dont know why sony does this i personally think it is to stop illegal burning via the internet.
3answers
My ps3 will play ps3 games but not dvds. it loads the dvd then turns black. Any suggestions?
You can follow below steps to play DVDs on PS3.
Step 1: Insert Blu-ray disc into PS3's Blu-ray drive. Playing Blu-ray disc movie works exactly the same way as entering a game, except you need to head into the Video Tab in your PS3's home menu, rather than the Game Tab. Highlight the Blu-Ray and press X to start it immediately.
Step 2: Now the Blu-ray disc will load like a traditional DVD. Use your controller to access the menu, and use the D-Pad to select your option and press X to enter. When the media is playing, you can press triangle to open a mini-menu that will give you access to options such as subtitles, audio channels and volume. You can also access the main menu, using the arrow keys to navigate. Press triangle again to close this menu.
However, if you can't do it successfully, try to convert DVD to regular video and transfer to PS3.
Step 1: Download and install Leawo Blu-ray to PS3 Converter, and then launch it.
Step 2: Get source Blu-ray movies ready. Insert Blu-ray disc to the Blu-ray drive, or get source Blu-ray folders ready for loading and converting.
Step 3: Load Blu-ray sources
Click "Add Blu-ray/DVD" button on the program interface. This Blu-ray to PS3 converter would then guide you to browse source Blu-ray movies for loading.
Note: After loading source Blu-ray movies, you could select subtitles and audio tracks, play source Blu-ray movies, edit Blu-ray movies, snap screenshots, etc.
Step 4: Do output settings
Next to the "Add Blu-ray/DVD" button, click the dropdown box and select "Change". You will then arrive at the Profile setting panel to select output format from "Format" group or "Device" group. Select "MP4? from "Format" or directly choose "PS3? from "Device > Sony".
Optional settings: After you've set the output format, click the same dorp-down box and click "Edit" option and then you could adjust video and audio parameters of selected profile, including: video codec, audio codec, bit rate, aspect ratio, frame rate, channel, etc.
Step 5: Start converting Blu-ray to PS3
Back to the main program interface, click the green "Convert" button. You could then set an output directory on the right popup sidebar. After setting output dirctory, click the below convert button to let this Blu-ray to PS3 Ripper instantly start converting Blu-ray to PS3 videos.
Note: Internet connection is required during the whole conversion.
After you convert Blu-ray to PS3 friendlier videos, you can transfer the videos to PS3 and then start to play Blu-ray on PS3 in a indirect way. For details, you can read the extension part.
For more details, check: Direct and Indirect Ways to Play Blu-Ray on PS3
4answers
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
3helpful
4answers
My new 3.15 ps3 won't play blu-ray but will play everything else no problem. no problems to play games or to play normal dvd's. When playing a blu-ray the UNIVERSAL part at the start of the movie plays...
f the Blu-ray Disc does not support 1080p 24Hz video mode, the video output may not display properly.
If a Blu-ray Disc movie is not loading properly or is freezing on a title screen, this may be caused by the PLAYSTATION 3 attempting to download BD-Live content from congested movie studio servers. If you experience this issue, you may choose to temporarily bypass the BD-Live content until the congestion at the movie studio servers has cleared.
Go to Settings icon (Settings) > Video Settings icon (Video Settings) > [BD Internet Connection], select "Confirm". Then reload the Blu-ray movie and the PLAYSTATION 3 will prompt you if you wish to allow the disc to access BD-Live content. Choose to not access BD-Live content to see if the movie will now load.
For some reason you seem to think this is a PS3 problem. Why do you think this is a PS3 problem? If you can play PS3 games, then I will say it is not a PS3 problem, as all PS3 games are on Blu-ray, and if you were having problems playing PS3 games, then that could account for the movie not working.
Since only the movie isn't working, I am going to say you have a defective Blu-ray disc. Did you just buy this movie, or have you viewed it before using the PS3? If you have never viewed it on the PS3, then the problem lies in the disc, and you need to take it back and have it exchanged.
If you have played the disc in the PS3 before (the PS3 you are having a problem with, not a different PS3 or Blu-ray player), or you still think it is a PS3 problem, then use the "Disc Troubleshooting" support page. Normally, if a Blu-ray movie will not play, it won't play at all, and it is because the Blu-ray laser has gone out. It sounds to me that the disc is bad, but this is only going on the information you have supplied.
Here is the Disc Troubleshooting support page mentioned above:http://playstation.custhelp.com/app/answ…
**EDIT**
Sorry, I just noticed you gave a UK link. Here is the support page for the UK. You will have to do a search on the site to find the Disc Troubleshooting page for your region.http://uk.playstation.com/support/
**EDIT**
Okay, here is your Disc Troubleshooting page for the UK:http://faq.en.playstation.com/cgi-bin/sc…
3answers
Will Not play the Blu-Ray disc
Silly anti priacy stuff. Doesnt even stop the pirates...
You just need to get the update, through it on a usb stick and update your ps3. Here is a link to the update and instructions. Hope it helps.
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html
3answers
PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
4answers
Ps3 plays video games, not bluray movies or dvds
I would start with a firmware update (2.60) and also a full system restore. That should fix the problem. Let me know. I'm a PS3 expert!
3answers
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
