Do you mean the 110VAC switch? Unless you are running the fridge on propane, it will need something to power it and if the camper is attached to power the fridge can be run on AC.
In the back of the freezer there is a ''condenser'' unit that leaks & ice forms along the...
(More)
In the back of the freezer there is a ''condenser'' unit that leaks & ice forms along the back of the freezer and bottom. I have opened a drain hole & attached a hose but the water freezes before it can drain from the freezer. What can I do?
My GE Profile TBX22PR ice maker seems to be leaking water on the floor. Is this because the ice...
(More)
My GE Profile TBX22PR ice maker seems to be leaking water on the floor. Is this because the ice tray somehow didn't get pushed back in properly? Or is there another problem? When I turn off the water line, the leaking stops.This happened once before, and when I removed the tray and put it back in again the leak stopped. But, this time it doesn't seem to correct the problem.
After 20 miles of very rough road we arrived at the camp ground lit the frig pilot and it will not...
(More)
After 20 miles of very rough road we arrived at the camp ground lit the frig pilot and it will not cool on LP. No electricity available. Worked perfectly before
I hav a !998 flagstaff,pop-up camper with a dometic frig.Model # RM4223, refrigerant R717,serial...
(More)
I hav a !998 flagstaff,pop-up camper with a dometic frig.Model # RM4223, refrigerant R717,serial #7330489.product#9211302-04,it's operating on 120vac ,but during the day it is pulling temp. of 50-57degr. installed in folding camper .Did get to 38 degrees over night, on a cool night plugged into 120vac in the garage.however it did not maintain temp the next day,as the day heated up .IT is not work on 12vdc n is not hooked up to 12vdc,and also could not get propane to lite. I dont think any propane was getting through. I.removed a tube,between gas inlet tube and a sort of gas control valve in back of unit,and found a small,white, filter like material inside this tube .Is That stuff suppose to be there and why?It seems to get cold during the evening, but starts to warms up as the day gets hotter.Does it cool according to the temperature outside?Do both the 120vac switch and 12vdc switch hav to be on when operating on 120vac? Does it alwys hav to be hooked up to 12vdc, if so why?Where can i get a manual and a diagram for this unit? I'd appreciate any help thank you john
