Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ticking noise I have a Whirlpool, Conquest side by side refrigerator and once in awhile it makes a loud, continuous ticking noise, like a clock. The noise seems to be coming from underneath and is driving me crazy, any solutions or hints ?
  • 1 more comment
  • Milkbone15 Dec 18, 2007
    looked at board and a small link in the green circut board is burned in half.
    What would cause this and Any way not to have to spend the $100 bucks to fix?
  • RuMcw Feb 01, 2008
    I have the same problem. There is a ticking noise that intermittently sounds from our Whirlpool Conquest. It seems to be coming from the bottom of the refrigerator. Does it have something to do with the water filter? Any ideas would be greatly appreciated?
  • Anonymous Mar 13, 2014
    Loud vibration noise behind below icemaker
    Problem Solver:
  • 5 Answers
Search google and type why is my refrigerator clicking,most sights say the start relay switch has gone bad.mines doing the same thing,if so its a 30$ fix
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=676782&PPStack=1
Posted on Dec 12, 2007
    Sergeant:
    Champion:
  • 262 Answers
This is the motherboard part number 2252189 it is getting ready to go out but before you replace motherboard make sure the unit is grounded a bad ground can also make the same problem happen
check ground at wall and all green wires on or around compressor and door hinges
Posted on Dec 07, 2007
Had ticking sound started up this am loud pop then rough running like there was no muffler
Ford Windstar Starting/Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Ford > Ford Windstar
Oct 16, 2007 - 31 posts - ‎26 authors
Learn more about Ford Windstar at the Edmunds.com Car Forums! ... I tried to startmy van on a 15 degree morning - heard a loud bang and now it won't start. Battery ....The engine will crank, start run about 5 seconds then stop. ... I have a 2003 Ford Windstar, same problem,Ford is covering up the problem.
Why My Car Won't Start? - Reasons and Solutions
www.myautorepairadvice.com/car-wont-start.html
As a rough guideline, problems with the battery, alternator and starter are the most ...Before I even put the key into the ignition I hear a clicking noise on the right side ...started it and then it started making a loud clicking noise while I was driving it ..... i have a 2003 windstar ford it was clicking and wouldn't start had to get a ...
Rough Idle Engine Dies Loud Ticking!?! Please Help! - Ford Focus ...
www.focusfanatics.com/.../103146-rough-idle-engine-dies-loud-ticking-...
Nov 6, 2006 - Rough Idle Engine Dies Loud Ticking! ... down then dies and then i restart and it has no problems but the ticking continues PLEASE HELP ME ... Level Up0% Completed ... 2. my injectors are bad and the ticking sound is one of the injectors.... Another method is to turn the AM radio on to a place where there ...Missing: windstar
Jan 08, 2016 | 2003 Ford Windstar
ELECTROLUX American Fridge Freezer making a ticking noise
Hey Jantoye4, thank you for your inquiry!
Based off what you have described your Electrolux freezer is making a ticking noise. This could be from your compressor or condenser. Additionally, you may hear this noise due to your defrost cycle. If you continue to experience the noise more or have another problem I would recommend contacting a professional technician for proper diagnosis and repair. Best of luck! -Matt
Feb 26, 2015 | Electrolux Refrigerators
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
The fridge makes a clunk noise. its like a clock ticking. its 6 years old.
YOU HAVE A PROBLEM WITH YOUR ELECTRONIC CONTROL AT THE BACK. MAKE IT REPLACED ASAP BECAUSE YOU WILL LOOSE EVERYTHING INSIDE.
PART NUMBER: WR55X10552 IT'S ABOUT 150$
Jan 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Makeing a loud noise. sounds like it is coming
take back lower cover off check the fan see if there is somthing in it, clean the coils while your down there take front grill off and clean there too, make sure you put the back, back on it needs to be there or fride will overheat
Dec 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Both sides are warm
can yiou tell me what the repairman did? the ticking is the air damper but the cooling is a separate issue. call a different repairman to have them take a look at the compressor, heat exchanger or evaporator as these could all the be source of the problem.
Aug 09, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,324 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
