recently my notebook will just freeze up and stop running...nothing..it goes blank..blue light on on/off button flashes...to restart I have to unplug and remove battery and then it will reboot..any thoughts about the issue that is causing this problem
This sounds like a power problem that I've seen before in Thinkpads (specifically, the x31). Under certain situations, the capacitors will become full and need to be "expressed" (for lack of a better term -- I'm not an electricity guru). Unplug, remove battery, and push the Power button down for about 2-3 seconds, 10 times. Then replace battery and AC, and you should be able to power on.
This can also be caused by something internal causing a non-fatal short in your motherboard, preventing the power-up process. The act of unplugging and removing the battery is enough to dislodge whatever is causing the short, but over time it makes its way back to that annoying place. When is the last time you had your laptop serviced? If it's still under warranty, I suggest a complete cleaning. If it is not, you can download the maintenance manual and either do it yourself, or have someone who has experience with laptops perform it. Trick with laptops is to be VERY detailed about what goes where, and be as gentle as possible. I do not recommend this for the novice who has no expert guidance on-hand.
Looking for manual for Compal TS30T. Also looking for photo's of the computer itself, need to know...
(More)
Looking for manual for Compal TS30T. Also looking for photo's of the computer itself, need to know what sits to the right of cd rom, have open space and wonder if battery sits there or goes on right side.
I have a Dell Laptop 10PPL which got dropped today while plugged into the battery pack. Now the...
(More)
I have a Dell Laptop 10PPL which got dropped today while plugged into the battery pack. Now the laptop buttons flash at the back orange and green, what does this mean. Did the fall damage the laptop or the battery charger or both. I'm so upset right now.
my laptop screen rolls. If i hold it at a particular angle, it will stop. My left hand is getting...
(More)
my laptop screen rolls. If i hold it at a particular angle, it will stop. My left hand is getting tired from holding the screen!
When I hit Fn and Spacebar the backlight on the keyboard of my HP Pavillion entertainment doesn't...
(More)
When I hit Fn and Spacebar the backlight on the keyboard of my HP Pavillion entertainment doesn't come on. Why not?
